10-03-2007, 10:52 PM | #1 |
Stock 69 K-20 350 pulley set up
I have a truck I am assembling from the pieces I pulled off the old/tired out 350 that the K truck came with. It is of course the short pump and has the stock externo regulated alternator. It also has power steering.
I believe the power steering could very well be a back yard add on. Clues are; a second thin stamped pulley with "woolered out" holes in 2 places to match the Chevy 3-bolt mounting. mounted behind the single groove damper pulley. There was a misalignment to the belt running the power steer pump from this added pulley. Also the power steering brackets have had some amateurish looking welding/fab done. Questions: I plan on using an internaly regulated alternator and from all of the FAQs on this board I understand that the pulleys are the same for my application. No change needed here from what I can tell. Sound good? My water pump pulley appears correct and is single row. There is a fan spacer. This should also be okay? So I guess I need to know if I can purchase the correct Damper pulley for the power steering set up with a short water pump. ??Numbers, sources, pics. are greatly appreciated. Also same for the pump bracket I would assume. A couple of close up shots of how the pump and brackets mount with headers would also be appreciated. Thanks once again for all of your good help. I was thinking maybe summit for a source? Maybe Brothers or Classic????? |
10-03-2007, 11:12 PM | #2 |
laying low
Re: Stock 69 K-20 350 pulley set up
I went to the salvage yard and found an engine with water pump, alternator, and steering pump setup like I needed and bought the matched set of pulleys.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
10-04-2007, 08:45 AM | #3 |
Good idea.
10-04-2007, 04:28 PM | #4 |
any more sources or ideas?
10-04-2007, 09:13 PM | #5 |
The pulleys are stamped with numbers and that may lead to possible answer as to the application when cross referencing to a GM parts book.
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
10-06-2007, 08:12 AM | #6 |
ttt
