Old 10-04-2007, 09:54 AM   #1
Alberta Newbie
Rivets between drum and Hub
Hello all,
I've recently switched out the hub on the right front wheel on my 2WD 69 GMC, and I had to use an hammer and punch to seperate the drum and hub (3 rivets holding them together). The replacement didn't have those little rivets, so i just installed without them.
My question is, do I need them, or will the lug bolts hold everything in place ?
Postal Code T8A 5V5
Alberta Newbie is offline   Reply With Quote
Old 10-04-2007, 10:26 AM   #2
raggedjim
raggedjim's Avatar
Re: Rivets between drum and Hub
You are good to go.
Rg
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
'73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203
raggedjim is online now   Reply With Quote
Old 10-04-2007, 01:44 PM   #3
68gmsee
Active Member
68gmsee's Avatar
Yep, I agree. That's the way I installed mine after a brake shoe change...
68gmsee is offline   Reply With Quote
