Patching floor and putting some new body bushings on 87
I am going to have to replace the passenger side front cab bushing, as well as the rear cab passenger side bushing. The truck always had an awful creaking noise at the passenger floor. There is actually a big rotted hole there, and the cab bushing is basically doing nothing, since it's just a hole in the floor. The back passenger side cab bushing is ok, it's just missing the bottom donut and shim. I know how to weld, but someone told me this is a two-piece floor or something? I don't understand this maybe someone can walk me through? Here is a pic of what I'm dealing with.
Re: Patching floor and putting some new body bushings on 87
And to add to this, the cab mount and cab support beams, look fine.
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
It is really hard to tell from the picture you posted where exactly the rust is, but you said it is over the cab bushing. The floorpans on these trucks are single walled. Here is a write-up of the 5 piece repair kit we sell being installed by a customer to give you an idea...
http://forum.73-87chevytrucks.com/sm...p?topic=5661.0
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
#4 | |
![]() Join Date: Jun 2007
It was kinda too late after all the metalwork, bodywork, and paint were done only to discover that the bottom of my door is scraping my rocker panel. I wasn't very happy to say the least as this was my first real attempt at this. I just wish that I'd have been able to have found a post like that before I started cutting on my truck. Is the only way to fix this to cut it all out and start from scratch again? I bought a brand new GM rocker panel and put it in the last time, and now it looks like I will have to scrap it if I need to cut everything out to redo mine. I replaced everything on mine, even the kick panel the last time, but I just can't live with it looking as it does. I'll bet mine dropped a good 1/2 inch at the front after I cut all the rust out, and I didn't even know it. I have already bought another GM rocker, Goodmark inner and outer cab corner. Do I need to order the inner rocker and all the other parts all over again to fix this? And one more question. How do you support the front of the cab up to get the alignment right? Floor jack and big long block of wood? If so, where do you place the wood so that you can be sure that it is going to be out of the way enough to fit everything up? Strange thing is that the right hand side went together without a hitch and looks really good. If I can't find a way to fix mine I'm looking at finding another cab that is rust free and just doing a swap. I really want to save my cab if I possibly can because I've spent quite a bit of time and money on it already. ...Joe
I'm not speedin'! I'm qualifyin'! |
Can you grind out the welds and start all over again using the same parts?
You can weld bracing between the front and rear door frame to keep everything level/stable before cutting it all out one you jack it into place.
#6 | |
Left side vs right side.
