10-04-2007, 06:30 PM | #1 |
oil question
i have an all stock 307 in 69 and its got 129000 miles and im runing castrol 5w30 highmilage oil. i was wondering is this the right oil for my truck?
10-04-2007, 06:45 PM | #2 |
Re: oil question
I know myself and a lot of others use 20W50.
72 C10 lwb fleetside -stock 350/350 combo |
10-04-2007, 06:55 PM | #3 |
Active Member
Re: oil question
Check your oil consumption. If it's not using a lot of oil after your regular oil change, then you're not hurting anything. However, it's a little on the lite side for summer or warm weather use on a high mileage vehicle.
With that many miles I would stick to a straight 30 weight or heavier in summer and then switch to the lighter 10/30 or there abouts for the winter. It's a matter of knowing what your motor wants or will operate better with. |
10-04-2007, 07:05 PM | #4 |
Re: oil question
I don't know what part of Washington you are in but if you are in the colder regions that would be OK for winter use.Frankly though I'd go with 10-30,or 10-40. Here in So.Cal.we have such mild winters,I just use 10-30 Mobil-1 all year. With a high mileage engine or when I expect to do a lot of desert driving (120+) I tend to go thicker and use 20-50 (Castrol).
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme. |
10-04-2007, 07:10 PM | #5 |
Re: oil question
i live in the dessert area (eastern/central part) of washington i ran 5w30 all summer so if i run to 10W40 or 20w50 before winter hits that would be a good idea.
10-04-2007, 11:55 PM | #6 |
Re: oil question
Here's what my origional owner's manual says;
10-05-2007, 11:25 AM | #7 |
Re: oil question
ive also got the original owners manual for my truck but never looked in it for the right oil.
