Junior Member
How can I run Side Exhaust on bags?
Does anyone have any ideas on how to run exhaust out in front of the rear wheels on a bagged truck with the stock trailing arms? I wonder if you could make a notch through the frame to allow the pipe to exit in front of the rear wheels? Or would that severely weaken the frame?
A guy with a truck
Re: How can I run Side Exhaust on bags?
Run it above the tranny crossmember, through holes cut in the trailing arm crossmember, and up and over the framerail right behind the cab. Check out Kyle4381's Blazer- he has something similar.
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
My exhaust goes outside the frame rails up near the firewall were the frame starts to jog down and the flowmasters are under the floor on the side and I have side exhaust, not running bags but it wouldn't change nothing except maybe raising the tailpipe a little for full drop
1968 Short Fleet 350/700r4 http://67-72chevytrucks.com/vboard/s...d.php?t=249435 1997 Bagged XtdCab Vortec350/4L60e http://67-72chevytrucks.com/vboard/s...44#post2286144 1993 XtdCab Longbed 4x4 6.5Turbo/NV4500 "Daily Driver" 1985 Toyota XtdCab 4x4 22re/W-56/Dual T-cases, Doug Thorley Header, Homebrew front and rear spring packs, Tons of Mods to suspension and drivetrain, 35" boggers, coming soon ARB's and 5.29's, Possible 4.3/700r4 swap |
Junior Member
I just did mine...I posted some pics prior...do a search under my profile name to find it.
going to sell this one...looking for a SWB project next. |
