Old 10-04-2007, 07:13 PM   #1
bigdon-70blazer
Wheel question
I just got some wheels from ridgeback and had to try them on for size. The new 16.5 X 8.25 wheel clearance is less than the stock 15 X 7. It does not touch but it is close as you can see in the pics. Is that OK?
bigdon-70blazer is offline   Reply With Quote
Old 10-04-2007, 07:21 PM   #2
bigdon-70blazer
Re: Wheel question
forgot the pics which I was having some trouble with earlier...
Old 10-06-2007, 12:09 AM   #3
tcb-1
Nothing to see here.....
tcb-1's Avatar
Re: Wheel question
big brother.....
you look fine. the geometry of the tie rod to wheel is not going to change through it's full range of motion. try turning the wheels lock to lock. if nothing touches, your gold.
if it happenes to touch, a simple 1" spacer plate may be in order.
tcb-1 is offline   Reply With Quote
Old 10-06-2007, 03:29 AM   #4
Angelse68cal
Cochino_Racing_909
Angelse68cal's Avatar
Re: Wheel question
Not only That but if you are closer on one side than the other ...You are gonna have to change some Ball Joints. I had to because My Tie rods where rubbing on the tire till I changed them .... I couldn't do anything until they where changed.
Angelse68cal is offline   Reply With Quote
