Old 10-04-2007, 11:23 PM   #1
BCOWANWHEELS
292 I-6 piston questions
i,am fixing to rebuild a 292 chevy engine and from what i understand the stock compression is 8.5 but if i use liquid propane gas pistons then the compression will be over 9.5 to 1. anybody got any info on this setup. i want as close to 10.1 compression as i can get. any help is appreciated.
bob
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 10-04-2007, 11:31 PM   #2
samwise68
FarmBoy.
samwise68's Avatar
Re: 292 I-6 piston questions
to my understanding, the LPG pistons bump it about a point in compression. i don't have specifics, but alot of guys do it on www.inliners.org.
also, have you considered using a 194 head? the smaller combustion chamber ups the compression nicely, i'm told.
-Sam.
1969 GMC C1500. long fleet.
307. 3 on the tree. 3.07 gears.
Oliver green. Bent and bruised. Daily Driver.
Screw patina... it's a beater...Beaters are cool.
my build thread - Project Homebrew:
http://67-72chevytrucks.com/vboard/s...d.php?t=242993
samwise68 is offline   Reply With Quote
Old 10-04-2007, 11:53 PM   #3
BCOWANWHEELS
not much info on that site. need some good tech on how to build a good stump puller engine. gonna check out the 194 head though.
thanks
bob
Old 10-05-2007, 01:59 AM   #4
Brad
Out of the carpool lane.
Brad's Avatar
Are you kidding??? Perhaps you didn't look long or do a search. There's ton's of info on L6's over there. Many have been in your boat and have posed the question.
194 heads are hard to find. Good luck.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
Old 10-05-2007, 05:49 AM   #5
67_C-30
I have a radical idea!
67_C-30's Avatar
I've got a NOS GM camshaft still in the factory cardboard tube if you need one for your build.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 10-05-2007, 02:03 PM   #6
BCOWANWHEELS
67 C30 Pm Sent.
Bob
Old 10-05-2007, 05:47 PM   #7
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
BCOWANWHEELS, although the 194 heads are getting rare there is also the option of milling your head to get to the CR you want.There are some sites with the combustion chamber specs and you will know your overbore.You need to know pistons and head gasket(it may help fine tune the CR).You should be able to get really close to your optimum CR this way.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 10-05-2007, 05:53 PM   #8
Blue71LWB
Blue71LWB's Avatar
I have heard that some of these inlines came with dished top pistons,is this true?. If so, adding regular flat top pistons would help the CR.
Working on my first 1,000 post.
I'm sure I'll get there before this project is over .
Blue71LWB is offline   Reply With Quote
Old 10-05-2007, 07:22 PM   #9
samwise68
FarmBoy.
samwise68's Avatar
all of the straight 6's, to my knowledge, came with dished pistons. it'd be the reason for the low compression ratio.
-Sam.
Old 10-05-2007, 10:05 PM   #10
BCOWANWHEELS
YEP ALL CAME WITH DISHED OUT PISTONS. only higher compression piston available is federal mogual #980p which is a 9-1 cast piston for lp gas engines. .150 deep dish . other than that only recourse is aftermarket forged pistons ( ouch ) $$$$$$$ so it looks like lp pistons for me..... now off to the machine shop with short block parts for cleanning and inspection to see if i,ve got a good rebuildable core.
bob
Old 10-06-2007, 01:49 AM   #11
rwgregory
FYI; 230's have flat top pistons...
rwgregory
67 GMC 2500 ,2w/d wide box
305 V-6, 4-speed
rwgregory is offline   Reply With Quote
Old 10-06-2007, 03:37 PM   #12
BCOWANWHEELS
i,am lookin for 292 pistons not 230 parts.
Old 10-06-2007, 05:14 PM   #13
chvtrkman
chvtrkman's Avatar
Bob,
What Brad said is correct. There is tons of info over at inliners.org. You have to do a search. Also, What samwise suggested about milling your head should help get you closer to the CR you want.
Yes, the inline pistons are dished as you stated, and the LPG pistons have less dish to them....bumps CR to 9:1. I have also read on inliners where some guys used 307 pistons(flat top).....if memory's working correctly.(?) I believe with the 307s you have to do some machining on them though.Not sure.It would be worth the $$$ to get hold of a copy of Leo Santucci's Chevrolet Inline Six Power Manual.There's good info in there .
I believe in John 3:16 also.
69 C-20 292, 4 spd O/D, 4:56 rears. No a/c p/s p/b p/w......restoration project,"Operation:Stovebolt"
78 C-10 305 TH350 new (old) daily driver
02 Suburban Z71 a.k.a. the family truckster
99 Silverado 1500 Z71
chvtrkman is offline   Reply With Quote
Old 10-06-2007, 06:06 PM   #14
samwise68
FarmBoy.
samwise68's Avatar
307 pistons work in a 250, and 283 pistons in a 230. unfortunately, the 292's pin placement is screwy, so a normal piston's deck hieght is out of whack on it. i think? idk. i just know that no other commerically made gm piston works in a 292. and it makes me sad. lol
-Sam.
Old 10-06-2007, 07:47 PM   #15
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Aren't 307 & 283 pistons the same ???
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 10-06-2007, 10:01 PM   #16
samwise68
FarmBoy.
samwise68's Avatar
the pin height, so to speak, is different. i think.
thats why you can't use a 283 piston in a 250 - the piston doesn't end up in the cylinder right when on the conn. rod.
atleast, thats what i think i read.
-Sam.
Old 10-06-2007, 10:53 PM   #17
67_C-30
67_C-30's Avatar
You're right, the pin location different on 283 and 307. The 307 has the 327 stroke (3.25") and the 283 has a 3.00" stroke. They both use a 5.700" rod, so the pin location is what changes. They are both 3.875" diameter.
My trucks
Old 10-06-2007, 11:49 PM   #18
mvfd70
mvfd70's Avatar
250's have flat pistons too. At least mine does
1978 Chevrolet Silverado 3/4 ton 400 small block.
2000 F-250 Powerstroke
2002 GMC Yukon Denali XL
mvfd70 is offline   Reply With Quote
