10-05-2007, 02:59 PM | #1 |
Who has the best replacement panels
Hi Y'all
I have a question about body panels. I'm working on a 1972 P.U. and she has a very small amount of rust on the floor right where the lip is that holds the door seal in place, less than 2" long and about ½ wide. I need help with this since I have never done this type of repair. So my question is who make the best replacement parts and is it hard to do. I do have a wire welder but I'm not that good at it yet, still practicing. I have had some good days welding and other days I should have never started. Thanks Bill8333
1972 K-10 L/B 4x4 Matching #'s 350 4 speed from the factory. P/S P/B 1981 GMC 1/2 L/B 4x4 one owner truck. 4" lift 2004 Dodge Cummins Diesel 4x4 Q/C S/B 1986 Dodge D150 L/B 2WD |
10-05-2007, 04:54 PM | #2 |
Re: Who has the best replacement panels
most of the panels all come from the same place (taiwan) so if you find a place thats cheaper or closer, or both, go with that one, as for replacing the panels, im not sure, its a little difficult depending on where the rust is. but if you have a mig welder at home just practice and measure everything before you do it.
10-05-2007, 06:18 PM | #3 |
The outer floor section from Tri-Plus is a good piece. It extends into the floor about 3 inches. There is a thread in the classified where it shows several installed including one on my Blazer.
Mike
Mike Redpath |
10-07-2007, 11:00 PM | #4 |
Thanks Ill look for it
10-07-2007, 11:12 PM | #5 |
Sorry but I can't find the post can you send me a link.
Thanks Bill |
10-08-2007, 12:08 AM | #6 |
Tri Plus all the way
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
