Old 10-05-2007, 03:23 PM   #1
highlow
smooth firewall
quick simple question,
why don't more people weld holes up on the firewall to smooth it out? To me this seems to be the simple way to go. Anybody have any reasons as to why? Or give me the reasons why it is better to just buy a firewall.
highlow is offline   Reply With Quote
Old 10-05-2007, 04:08 PM   #2
solidaxel
solidaxel's Avatar
Re: smooth firewall
It was easier to fill a portion than replace the whole fire wall for me!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 10-05-2007, 04:25 PM   #3
bfink
Re: smooth firewall
i plan on starting to fill what seems like 500 holes in my firewall this weekend , we'll see how it goes!!
bfink is offline   Reply With Quote
Old 10-05-2007, 05:17 PM   #4
robin58
Re: smooth firewall
I did the same as solidaxel. Areas with a lot of holes I simply made a smaller panel to fit and weld in. Only advantage I could see going with an aftermarket one is to gain some additional space around the distributor using a setback firewall.
robin58 is offline   Reply With Quote
Old 10-05-2007, 05:51 PM   #5
pgf545
pgf545's Avatar
Re: smooth firewall
I did the whole firewall because the old firewall was hacked beyond repair.
Bernie
52 Chevy Truck (Dad's)
http://67-72chevytrucks.com/vboard/s...d.php?t=206021
pgf545 is offline   Reply With Quote
Old 10-05-2007, 07:16 PM   #6
mylow53
mylow53's Avatar
Re: smooth firewall
some of the issues you need to deal with on the smoothed or filled firewall are where the wireing harness goes and if your using ac where and how to connect your bulkhead fittings. i'm doing the filled not smoothed firewall and am hopeing to run my wires thru the inner fender. we will see... i still have 3 or 4 holes left.. i will probably leave the dash mounting bolts in, 4 nuts is't a big deal
Greg
1953 chevy 1/2 ton 5 window, chevy 350 330 horse 700r tranz, lowering spindels mustang 2 frount. ford 9", airbags on 4 corners . purchased in 1983 for $325 while in high school
http://67-72chevytrucks.com/vboard/s...=215079&page=5
mylow53 is offline   Reply With Quote
Old 10-05-2007, 07:31 PM   #7
solidaxel
solidaxel's Avatar
Re: smooth firewall
I tried too keep all of my wires out of sight and the A/C plumbing to. I ran everything on the inside of the inner fenders, wiring on the left and the A/C on the right, I welded some bolts to the I/fenders and then some conduit and hid all the wires. to the lights The a/c hoses and dryer are where they would normally be on the i/fenders but on the wheel side. I entered the cab by making some holes in that area where the fenders bolt to the cab (there is enough room for 2 heater hoses and 2 a/c hoses). I ran the wires the same way on the drivers side.
LS 3 4L70E
Old 10-06-2007, 11:30 PM   #8
CAL 58 GMC
CAL 58 GMC's Avatar
Re: smooth firewall
I used a one piece fiberglass fire wall from Brother. It was simple to install and covers all the holes at once.
CAL 58 GMC is offline   Reply With Quote
Old 10-07-2007, 01:15 AM   #9
Kim57
Kim57's Avatar
Re: smooth firewall
I made my own from 16 gauge. The original was rusted and would have been just as much work to repair. I still need to mock up the engine position and make a relief for it.
Kim
Kim57 is offline   Reply With Quote
Old 10-07-2007, 09:28 PM   #10
chevyrestoguy
chevyrestoguy's Avatar
Re: smooth firewall
I got tired of welding up all the holes (58....yes, 58). Plus, I figured that it would have been a nightmare to do the bodywork and get it smooth due to all the raised rib areas. I needed a 3" setback for the big block to clear, so here's what I did:
chevyrestoguy is offline   Reply With Quote
Old 10-07-2007, 10:02 PM   #11
pgf545
pgf545's Avatar
Re: smooth firewall
Here are a couple of pictures on my dads truck with the *****in firewall kit and floor.
Old 10-07-2007, 10:40 PM   #12
Bills_49
Broke Club =(
Re: smooth firewall
I like that set up, thats from brotherstrucks.com?
Bills_49 is offline   Reply With Quote
Old 10-08-2007, 12:39 AM   #13
lotussutol
Re: smooth firewall
It is located here on the brothers site...
http://www.brotherstrucks.com/prodin...number=FFC5559
I was looking at a setup like that too but I am going be mounting a firewall mounted brake setup on the firewall. I think the fiberglass would be weak and shatter and I am not sure if the original firewall underneath the fiberglass cover would be strong enough either.
This is what was done in my 52 chevy...It is an aluminum cut out to cover the firewall. I will probably do the same with the truck but do it in black this time.
Lotus
Current Rides/Projects
1955.5 Chevy shortbed truck
1952 Chevy Coupe Deluxe car
lotussutol is offline   Reply With Quote
Old 10-08-2007, 01:06 AM   #14
Kabwe
Certified Car Nut
Kabwe's Avatar
Re: smooth firewall
Heres what I did.
Kabwe is offline   Reply With Quote
Old 10-08-2007, 09:43 PM   #15
CAL 58 GMC
CAL 58 GMC's Avatar
Re: smooth firewall
Lotus beat me to the answer, yes it is brotherstruck.com Here's a look at after paint.
Old 10-09-2007, 06:07 AM   #16
prostreeter58
prostreeter58's Avatar
Re: smooth firewall
Here is the metal one from brothers...........same concept as Cal58's but this one is welded in over top of the original firewall.
prostreeter58 is offline   Reply With Quote
Old 10-09-2007, 10:30 AM   #17
orgalmeister
Re: smooth firewall
I filled the holes before and after pics
orgalmeister is offline   Reply With Quote
Old 10-09-2007, 11:14 AM   #18
lotussutol
Re: smooth firewall
your hired! when can you start? j/k
Nice firewall! I was sanding on mine last night some. I am hoping to make some templates today so that I can have some 1/4" aluminum panels made to fill in the firewall.
Lotus
