Old 10-05-2007, 03:23 PM   #1
Nima
Blue 67
Painting advise
Hi to all:
Well, I did some readings, here on paint section and some books. Now I did some practice and this is my problem: paint looks dull. It is my problem not the quality of the paint (although I bought some cheap paint for practice)since in some spots it looks very nice and shiny. somehow I think I have problem with adjusting the trigger. The shiny spots are easily turn to runs!!. I try to keep my hand steady and at the same distance but even the clear coat looks dull ( I tried few coats of paint few days ago and today, I tried some clear coat). Any inputs?
thanks
1953 GMC 3/4 ton: current project
1967 C20: 5.3 voretc with T5 conversion, 4 wheel 8 lug disc brake
1972 Nova: my 4 door sport sedan! 5.3 voretc + T5 conversion. drivable project, FUN!!
1979 Camaro Z28: 5.3 vortec conversion with build TH350: drivable project, Fun to drive
1992 Camaro RS convertible (Z28 clone): 5.3 conversion with build T5: on going project
2005 Silverado 2500, 4x4 Duramax, original owner
Nima is offline   Reply With Quote
Old 10-05-2007, 03:40 PM   #2
Dad's Truck
Dad's Truck's Avatar
Re: Painting advise
Paint may be going on too dry. It's a balancing act between too dry and the runs.
Is is BC/CC? If so, the base coat will be dull. The clear coat will buff out to the high gloss.
Tell us more about what you're using.
Bob
Dad's Truck is offline   Reply With Quote
Old 10-05-2007, 04:18 PM   #3
Nima
Blue 67
Re: Painting advise
The paint is Acrylic Enamel. I am just practicing on a door which I took out my parents 1999 ford escort whcih I believe had Acrylic paint from factory. Based of the instruction on the website (I got it from carpaintonline.com) I didn't have to use reducer or hardner. Even they said I don't have to use clear coat unless I want longer lasting paint. The clear coat was from them as well.
No what is BC/CC that you asked?
My paint gun is a cheap gravity feeder conventional.
Old 10-05-2007, 08:02 PM   #4
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
Re: Painting advise
You need to lay on some clear let it tack up good (time may vary) recoat & repeat until it all looks shiny. it's not necessarily a one shot deal.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
