10-05-2007, 04:31 PM | #1 |
Junior Member
Who has info on raising the bed floor??
I am looking for any info/pics of this custom work...raising the bed floor to c-notch the truck with out having to cut bed floor. Thanks.
going to sell this one...looking for a SWB project next. |
10-06-2007, 02:17 PM | #2 |
Junior Member
Re: Who has info on raising the bed floor??
Anyone??
10-08-2007, 12:19 AM | #3 |
A simple bolt-in c-notch doesn't require the bed floor to be raised. A step notch where the clearance above the rear-end housing is taller than the original frame does require floor mods.
Which do you want to do?
10-08-2007, 12:27 AM | #4 |
Look for "project slow build" by rokcrln and you can check out how I did one of mine.
Kevin LFD Inc. |
10-08-2007, 07:16 AM | #5 |
Junior Member
I dont know what to do...I have airbags and currently riding on the rear bump stops. I checked the clearance from the top of diff to the bed...its about 3 inches. What options do I have? What is the diff between a bolt in notch and anything else? Sorry...new to this method
10-08-2007, 10:00 AM | #6 | |
10-08-2007, 10:15 AM | #7 |
Junior Member
Stock...But remember its a lwb truck. I have not seen a aftermarket one for the lwb...only the swb. (are you asking due to the driveshaft?)
10-08-2007, 11:56 AM | #8 | |
Did you modify the original bumpstops?
10-10-2007, 01:12 PM | #9 |
Junior Member
No org bump stops are still there. Sorry it took a few days to respond...I have been away. Thanks
10-11-2007, 10:10 AM | #10 | |
I would remove the factory bumpstop & bracket. Install a bolt-in notch & then adjust the supplied bumpstop so that it keeps the rear end 'pumpkin' from touching the bed floor. The kit I got from CPP had a urethane bumpstop included (like a traction bar snubber) but I've learned they might now come w/the short 'pancake' style urethane type. In order to get the last bit of suspension travel possible while keeping the rear from touching the floor, the short type might requiring 'shimming' it up to make it taller & the longer type might require cutting it down.
10-11-2007, 10:34 AM | #11 | |
Junior Member
Perfect..just ths info I wanted. Now how hard is it to install a bolt in notch? What do I need to worry about when doing it?
10-11-2007, 12:33 PM | #12 | |
What areas to be concerned about? Double check & make sure the center-line of the notch is centered over the axle housing when air'd out. My instructions said to mount it X amount of inches from a fixed hole in the frame. If I would have followed the instructions, the notch would have been off-center about 3/4". Use grade 8 hardware. Drill holes for all your corners before cutting the frame as it helps prevent stress-cracks from forming @ the corners of the cuts.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 10-11-2007 at 12:35 PM. |
