rear cab seam panel?
does anyone know where to get a panel that you can weld in the place of the rear cab seam at the top?
Commander Taco Bello
Re: rear cab seam panel?
not sure there is a panel. if i read your post right, you want to remove the seam.
why not just weld it up? |
![]() Join Date: Jul 2006
I'd like to hear how people get rid of this seam also.
Cheers, Tony A day without sunshine is like, you know, night. 1970 Chevy CST10 (Green) 2005 Silverado Z71 2000 Pontiac Bonneville |
Do a search for shaving drip rails. I don't think they make a panel. I'm sure all you can do is fill it in if your shaving drip rails. If not you can reseal the seams/drip rail. There was a thread a few days ago about restoring drip rails.
I had my drip rails shaved and the rear seam welded smooth. It has to be welded, if you try to fill with body filler it will crack.
![]() Join Date: Aug 2005
Porterbuilt did it too. He replaced the seam area with rolled/formed pieces.
