Old 10-05-2007, 08:01 PM   #1
loader820
350 sb
the number one lifter is lose an it sound like it missing but all new plug an wires had cam work done an no speed like before what should i change all the liter are get new head the head are iron head
loader820 is offline   Reply With Quote
Old 10-06-2007, 04:10 AM   #2
xtreme80
Wishin' I had more money!
xtreme80's Avatar
Re: 350 sb
Ummm...
Your lifter is loose? Or your rocker is loose? Why can't you tighten it up?
Really confused on this one...
xtreme80 is offline   Reply With Quote
Old 10-06-2007, 07:32 AM   #3
loader820
Re: 350 sb
my rocker are loose an can not tighen them no more will that make it loose compresson
Old 10-06-2007, 07:34 AM   #4
loader820
Re: 350 sb
if i get the head redone will i needs to do the cam to
Old 10-06-2007, 09:31 AM   #5
ocbaud
Garage Queen Material
Re: 350 sb
Originally Posted by loader820 View Post
The number one lifter is loose and it sounds like it's missing. It has all new plugs and wires. It recently had cam work done but has no acceleration like before. What should I change? All the lifters are new. The heads are cast iron.
My rockers are loose. I can not tighten them any more. Will that make it loose compression?
If I get the head redone, will I need to replace the cam too?
I corrected all of your vocabulary. Maybe now you might get an answer to your question since it took me 10 minutes to figure out wtf you were trying to say.
ocbaud is offline   Reply With Quote
Old 10-06-2007, 11:33 AM   #6
454HO
Re: 350 sb
Thanks for interpreting that ocbaud.
First question I have is are the rocker studs press-in or screw in? It sounds like they are press-in and they have worked their way out. Yes, that will make the engine lose compression. I do not think it is possible to fix this without removing the heads and having a machine shop tap them for screw in studs. I have heard of 'pinning' press in studs, but they would need to be set at uniform heights first, then the boss is drilled thru the stud and a roll pin inserted - not easy to do with the head on the engine intalled in the truck.
Next question is what are the specs for the cam you have installed? Is it hydraulic or solid, roller or flat tappet?
Third, what is the seated pressure, installed height, and coil bind specs for the valve springs?
Fourth, what is the rocker arm ratio?
Fifth, what length pusrods do you have? Did you check the valve geometry to make sure they are the correct length for your engine? And have you made sure none of them are bent?
- Greg
454HO is offline   Reply With Quote
Old 10-06-2007, 12:55 PM   #7
loader820
Re: 350 sb
the rocker are screw in the push rod i does knew if they are bent i got the from out of my state an did not know what all he did with the engine he use th race with it
Old 10-06-2007, 05:49 PM   #8
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Re: 350 sb
Exactly about what I was going to ask as well, just got beat to it. And many thanks to ocbaud for helping me understand the jibber jabber. The posts are still confusing as all get out.
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 10-06-2007, 09:14 PM   #9
chevyjeff59401
Re: 350 sb
I would consider the fact that your cam may be going flat. If you pull the valve cover off and have someone turn the motor over, you should be able to see if that pushrod moves up and down as much as the others. Jeff
chevyjeff59401 is offline   Reply With Quote
Old 10-07-2007, 12:01 AM   #10
xtreme80
xtreme80's Avatar
Re: 350 sb
http://hooked-on-phonics.com/
