Old 10-05-2007, 10:45 PM   #1
WinDancer
The Original HotRod KnifeMaker
WinDancer's Avatar
long-lasting bulbs even when pounding the truck?
I have finally had enough of replacing bulbs every week because of my very rough and long driveway.
Have you off-roaders found bulbs [headlights, taillights, running lights, dash lights, etc] that hold up well off-road?
I know the LED lights last a long time but do they last off-road as well?
Had the same problem with my shop drop lights- switched them over to appliance bulbs and they now last quite a while, instead of a new bulb every time they are used.
I replace at LEAST one bulb every week on all our vehicles.... real tired of the hassle.........
Thanks,
Dave
69 GMC SWB 2WD 454 Turbo 400
WinDancer is offline   Reply With Quote
Old 10-06-2007, 07:13 AM   #2
mothertrucker424
mothertrucker424's Avatar
Re: long-lasting bulbs even when pounding the truck?
ya know i do the same thing i always considered it to be the age of the truck
mothertrucker424 is offline   Reply With Quote
Old 10-06-2007, 05:53 PM   #3
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
I usually don't have too many problems but I don't really have any suggestions either.
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 10-06-2007, 07:18 PM   #4
earl87gta
earl87gta's Avatar
The LED will last forever your not going to bust an LED light by vibration like a reguler light . My Buell use to go threw tail lights around 1 a month from vibration I put LEDs in it and I havent replaced one in 3 years.
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
Old 10-06-2007, 08:43 PM   #5
Musclerodz
LED's and H4 bulbs will last longer than any filament bulb. Can't garuntee they will last forever, but the LED's we carry have a lifetime garuntee so you should never have to pay for those again at least. We can also supply DOT legal H4 headlights as well.
Mike
Mike Redpath
Musclerodz is offline   Reply With Quote
Old 10-07-2007, 09:53 PM   #6
WinDancer
WinDancer's Avatar
It's not the age of the truck- I bought my F250 [I know, I know, down, guys] new and started replacing bulbs the first week. Marker lights, tail lights, headlights....
Three years???????????????????? THAT is sweet!
So how does that work, Mike? If I buy the LEDs from you and have one or more burn out I have to send them back and then wait for you to send a replacement? I appreciate the thought but a new regular bulb is cheaper than shipping
Also, aren't the LEDs soldered in so you would have to solder in a new bulb if one went out?
I have been reading for a couple years now about how the LEDs outlast regular bulbs, but mine don't wear out they just get vibrated so bad they just quit Broken filaments].
I guess I don't understand enough about how the LEDs work??????????
Thanks to all,
Dave
Old 10-08-2007, 12:08 PM   #7
Musclerodz
Thanks to all,
If you have a board fail, send it back and I will replace it. A bulb may be cheaper then shipping, but if your buying bulbs weekly, shipping will be cheaper in the long run. LED's don;t have filaments to break, they should last for quite a long time. I have several guys running LED's in there trail rigs and no one has called to have one replace yet.
Mike
Mike Redpath
