Old 10-05-2007, 11:39 PM   #1
the_goat
another steering question
Where should I start as far as improving the steering on my 70 blazer with a 2.5 with 33's? It drives pretty well but every once in a while feels like it's going to jump off the road to the right. Then when I straighten it out it goes to far to the left and I have to pull it back to the right. Does this make sense or sound familiar to anyone? I'm trying to describe it as best as I can but I don't know anything about steering. I brakes in a straight line if that means everything. The steering box does leak from where the shaft goes in.
the_goat is offline   Reply With Quote
Old 10-06-2007, 12:20 AM   #2
Southedisto
River life......
Southedisto's Avatar
Re: another steering question
Sounds like something is amiss in the alignment.
Southedisto is offline   Reply With Quote
Old 10-06-2007, 11:25 AM   #3
pumpkin
pumpkin's Avatar
Sounds like a broken torsion rod in the box. This is what keeps the spool valve, that directs the high preasure ps fluid in the box to assist turning. When the rod is broken, wichever way you turn the wheel gets full assist untill you manualy forc the spool valve the other way. One way to test for this, is with the engine running if you move the steering wheel one way and the wheel keeps turning by itself, the the torsion rod is broken.
pumpkin is offline   Reply With Quote
Old 10-06-2007, 04:28 PM   #4
the_goat
Thanks for the tips, I'll go try it right now.
Old 10-06-2007, 08:13 PM   #5
zeeklu
I had a frozen axle u-joint and it acted similar . Chris
zeeklu is offline   Reply With Quote
Old 10-08-2007, 07:31 AM   #6
OLDCHEV4X4
OLDCHEV4X4's Avatar
I had a set of biasply tires that acted like that. I put up with it for a couple years. When i changed my tires it went away.
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 10-08-2007, 12:57 PM   #7
the_goat
The tires look like they are in hood shape. The tires don't seem to keep turning when it's in park but that is exactly what it feels like when I'm driving. The steering box is leaking anyways so I'm going to replace it, get a better steering stabilizer, and then an alignment. It really drives pretty well I can just tell that something is not quite right.
Thanks for all of the help.
