10-06-2007, 12:09 AM | #1 |
Power steering questions???????
the power steering is in, but it's way to soft as-in to much power assist, Jeg's has a shim kit to reduce the pump pressure for rack & pinion steering, my dad installed it in his 49 and it quit blowin' out seals, but I'm using a stock 72 power box and stock pump, so what i want to know is if which way do I need to adjust the pressure to stiffen the steering?
10-06-2007, 11:17 AM | #2 |
Re: Power steering questions???????
Its not the preasure that is the problem. Its the reaction rod in the box. There is a torsion spring in the ps box that is designed to give the road feel, if it is weak, too small, or broken, the power steering will fell very easy. I run a hydraulic winch on my Blazer an have upped the preasure from 750 psi to 1800 psi. It made no difference to the power steering feel.
10-06-2007, 12:13 PM | #3 |
Thanks, looks like I'll tearing into the box.
10-06-2007, 01:02 PM | #4 |
try adjusting the allen screw on top. It adds more friction and makes it feel a bit stiffer
'72 K5, known as 'the Fox.' |
