Old 10-06-2007, 03:29 PM   #1
drbyrdman
drbyrdman's Avatar
front shock braces
Anyone know were to get the front shock braces that bolt on to the frame to give the front shocks more strengh
drbyrdman is offline   Reply With Quote
Old 10-06-2007, 08:25 PM   #2
jlaird
jlaird's Avatar
Re: front shock braces
I'm not sure what I understand. More strength than the stock bolt going through the frame? The stock upper mount is pretty damn strong if you ask me. Air ride has a bolt on shock relocater if your looking for more travel??
jlaird is offline   Reply With Quote
Old 10-06-2007, 09:08 PM   #3
jasonb72
PorterBuilt Man Crush
CPP is the one I always see advertising it. I do like the ART mount 2
The 72 will live again
jasonb72 is offline   Reply With Quote
Old 10-07-2007, 10:47 AM   #4
LONGHAIR
Why would you need more strength? The shock should not be limiting suspension travel, so the only load should be in the hydraulics of the shock itself. The stock bracket is plenty strong.
LONGHAIR is offline   Reply With Quote
Old 10-07-2007, 11:10 AM   #5
drbyrdman
drbyrdman's Avatar
Looks to me like it was broke for a while and made the hole in the frame bigger. I will have to weld it later. for now I fitted a washer in there and sandwiched it with two bigger washer on the frame. I found a brace at CCP. I am going to add that a get the frame welded .
