Old 10-06-2007, 04:57 PM   #1
tominator67
Exhuast headers question
If I install headers on my 283 what will i do about the alternator support thats built into the manifolds?
tominator67 is offline   Reply With Quote
Old 10-06-2007, 05:10 PM   #2
Big White GMC
Big White GMC's Avatar
Re: Exhuast headers question
Most Performance Catalogs Have A Bracket That Works For That Situation . Summit, Jegs, And The Other Companies Sell Them With The Exhaust Kits. Those Headers Will Help That 283 Breath. Good Luck !!
It's A Beautiful Day In Suburbia !!!!!
Big White GMC is offline   Reply With Quote
Old 10-06-2007, 09:41 PM   #3
BCOWANWHEELS
you could swap your cyl. heads for the 305 ho heads and upgrade your engine and then have accessorie bolt holes. good swap for a 283
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 10-06-2007, 11:05 PM   #4
Gray Ghost
Gray Ghost's Avatar
I made one from an old stock manifold stud [2" long I think] and two nuts on an Elky once. The two nuts are spun on together right where the mount needs to be. Not sure what your bracket needs to be shaped like, but if it was bolted right to the manifold that should work well for you.
Kelly
'05 GMC Sierra SLE Z71
Bone stock except for new bed rail caps.
Gray Ghost is offline   Reply With Quote
