Sierra Grande Club
Roller rocker hitting stud shoulder….
I got ready to mock up my engine and noticed when I adjust my rocker it hits the shoulder of the stud mount. (Stock heads w/screw in studs). I did the procedure where you set a 0 lash, then turn 3/4 turn more. From the pictures it appears I need shorter push rods….this will make my problem worse. These pictures are taken with 0 lash, they hit when I get close to 3/4 turn.
Ideas? s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. ![]() Last edited by Sport/Truck; 10-06-2007 at 06:22 PM. |
Re: Roller rocker hitting stud shoulder….
You most likely need +.100 push rods......Same thing happened to me. I went down to my local speed shop and bought an adjustable push rod from Moroso. For every 1 turn of the adjustable push rod, it is +.100 longer. It also tells how to use it. I used a magic marker on the valve stem tip, and then put on the rocker arm. Turned over the engine and that will show you how far forward and backward the roller moves on the valve stem tip. Adjust the pushrod until you have very little forward or backward movement. Then see how many turns of the adjustable pushrod there is. Hope this helps.
1997 GMC Sierra Ext 1965 Mustang Last edited by 70GMCer; 10-06-2007 at 06:27 PM. |
#3 | |
Sierra Grande Club
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. ![]() |
If you put shorter push rods in it will move the rocker closer to the head. Longer push rods will move the rockers up away from the head.
What about big block push rods? are they any longer? or to long? Frank
70 chevy lwb c10 454/th400 and a 9" rearend suicide doors, marker light fuel fill, 4" cowl , mini tub |
Sierra Grande Club
longer push rods aren't hard to get, but it will push the roller tip out more. do you think it will be too much? It looks like it needs to have shorter rods?
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. ![]() Last edited by Sport/Truck; 10-06-2007 at 07:39 PM. |
As long as you don't go to much you should be fine. If you go with +.100 as stated above you should be ok. Obviously you don't need very much so try to keep it close to what you have already.
I would also call who ever made the rockers and see what they suggest or possibly the company you bought them from. Summit and Jegs have a tech line to call that could be of some help. I think the best bet would be calling the company that made them and see what they recommend for pushrod length. Frank
#7 | |
Sierra Grande Club
s/t
I had this problem on a 327 I built. Took a long time solving. My problem was I was using new lifters that I didn't pump up with oil first. When turning the pushrod on dry lifters with my fingers tips, It still rotated until I was way to deep into the lifter. I tried to start the car and it spun like an electric motor. No compression. I removed them and put into a pan of oil and worked the plunger with a pushrod, reinstalled with no problems. This will raise the heal of the rocker off the head. Hope this helps.
72 Chevelle Club
I had this problem on mine also . I took the rockers off and put stamped steel long slots on it . Solved my problems !!! Don't look as pretty as the rollers!! Oh Well
I Have The Right To Remain Silent,But Lack The Ability 1972 Chevelle ... Mine 2006 Trailblazer... Hers 2002 Buick century ... Kids 2002 K1500 Z-71 EXT CAB ... Daily Driver 2005 Rockwood Roo ... For Camping 1974 Harley-Davidson XLH Sportster 84'' stroker |
Sierra Grande Club
I checked the rocker, taking care to measure at the precise point that the push rod pivots in the rocker. I checked the rocker’s position on the valve stem, and it’s in the middle.
Will this work? Are most of yours in the middle of the stud on the base circle? s/t
#11 | |
Sierra Grande Club
s/t
![]() Join Date: Nov 2006
ARE YOUR LIFTERS PUMPED UP WITH OIL FROM RUNNING ? DID YOU LET them soak in oil over night before installing them ? set at 0 lash and crank engine the adjust them.
I BELIEVE IN JOHN 3:16 |
#13 |
I am a Referee of life.
If the fixes above did not fix them there was a story in one of the mags(Probably Car craft or Chevy HP0 where they had this problem and had the rockers ground or milled in the area that is hitting.It was very minor but gave them the clearance needed.I believe the rocker manufacturer gave them the solution.Sorry I can't say which mag I read about 10-12
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
#14 | |
Sierra Grande Club
or the other option is to mill the head where the stud screws in. s/t
#15 |
Next project: 1970 K10
Your original post said screw in studs, but the pic looks like OEM press in studs? Am I missing something there? All the SBC I have done with screw in studs had to have the boss milled way down.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE Last edited by glock35ipsc; 10-07-2007 at 01:32 AM. |
#16 |
Sierra Grande Club
I went the cheap way, no mill work just taped & threaded.
Most people have them milled to use guide plates, and they require the special stud with the hex head which reduces flex. I may end up havening to have that done after all, if I didn't screw myself. since they are already drilled and tapped they may not be deep enough for the other style studs. My original intention was to use stock or roller tipped stamped rockers. s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. ![]() Last edited by Sport/Truck; 10-07-2007 at 09:41 AM. |
#17 |
Overdrive club
Im wonderin if that type of rocker arm stud is compatible with that style of rocker??
1971 c-10 1951 3100 chevy 1970 chevy c-30 Sold! |
#18 |
More info. 350--StocK head--stock spring--stock lifter. Pumped up, or not?? What rocker was ordered and what push rod and length? Studs a stud. Wouldn't think thats an issue.
#19 |
Not necessarily so.
If you mill the pads and use a quality screw in stud with the hex head you will have plenty of clearance. If the rockers are self-aligning you won't need to use guide plates. But even if they were self-aligning, I would use guide plates myself. They are cheap insurance.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
#20 | |
Sierra Grande Club
These are scorpion rockers (house brand) and using the old stock push rod to mock up and check length. which looks like I need shorter rods...making my problem worse. ![]() the studs are screw in. s/t
#21 |
Spanked once
![]() Join Date: Oct 2006
You only need to do it to one lifter to check it by pumping it up in some oil and putting it back in.
You want zero lash then set it at .002 with a feeler gauge. Please forget spinning the push rod.... it's up and down motion only. The.002 will will probably get you feeling better at what you are seeing. Look at it this way ,you are using Lunati springs , roller rockers , and new lifters, soooo... a non stock valve train does not have a manual to adjust with. If you do this and still have the rocker issue then longer push rods will help. You need to pump up those lifters,, you got nothing to lose by doing it. |
#22 | |
Sierra Grande Club
While I was taking this picture, I got to looking at the slot....and it didn't look like it was big enough for the rod to pivot the full .486 that it needs.... ![]() looks like may need to have this machined. I hope it won't be a problem since my heads were already drilled & taped. s/t
#23 |
"Trucks with Class"
![]() Join Date: Jul 2000
You need to go to a "good" machine shop that does performance engine work on a regular basis. They will have the right answers and the right equipment to do the job.
It helps if you do the clearance checking using either a light testing valve spring or a solid lifter that sits the push rod in the same position as the hydrolic. The heavy springs may be pushing the lifter down at full lift/pressure. |
#24 |
If they are not self-aligning rockers, and you don't you guide plates, that is a recipe for disaster. Something needs to hold the rocker in line with the valve stem and the push rod.
I'm not so sure the non-slotted push rod holes will matter too much if you aren't using a high lift cam. I've ran some big ones without having a clearance issue there. Of the SBC heads that I have built, the slotted push rod holes are narrower to keep the push rod straight. The newer crate motors, with the bigger hole, use a rocker arm that is slightly recessed at the valve stem to keep them from sliding off one side or the other. The thread size should probably be the same. The machine shop will mill the boss down enough to make room for the guide plate and the hex head, and will drill a little deeper if they need to and tap the fresh hole. If you want to run rollers on that head, you will NEED either self aligning rockers OR guide plates.
#25 | |
Sierra Grande Club
My concern is that these were already drilled & taped. If they need to re-drill to go deeper- then it will take away some of thread in what was already done. I'll get back tonight with the word from the shop. ![]() Thanks to everyone for the help. s/t
