Old 10-06-2007, 06:59 PM   #1
Tigman
Shaving drip rails!
Finally got a start on my 68 4wd project. Cut out all the interior sheet metal panels to get rid of all rust! Got it blasted and primed! Now on to the drip rails!
Mark
Tigman is offline   Reply With Quote
Old 10-06-2007, 07:06 PM   #2
Andy4639
Old member
Andy4639's Avatar
Re: Shaving srip rails!
Looks like you have a lot of work in front of you. I wanted to do the drip rail's on mine but money lady said NO! Oh well can't wait to see finished product.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 10-07-2007, 12:55 PM   #3
Mordachai
Fat Fendered Fleetside
Mordachai's Avatar
nice job. I have a good bit of rot/rust around the upper corner of the windshield. I think I'm going to shave them off during the repair instead of trying to fix them...
how much did you cut off and weld up at a time? I have heard about 4-6" at a time, but it looks like you did much larger sections....?
|M|
71 GMC lwb
56 Big window swb
93 GMC Sonoma (dd)
radiused fiberglass fender project for 67-72
Mordachai is offline   Reply With Quote
Old 10-07-2007, 10:02 PM   #4
Tigman
Re: Shaving drip rails!
I used 16 guage 1 5/8 wide and 12" long for the center and the next 2 outters! Then progressively short as I went outboard! I did it to get rid of the rust also!
Mark
Old 10-08-2007, 11:48 AM   #5
Mordachai
Mordachai's Avatar
Cool, I think I am going to pull my cab off and get into it this weekend. Just need to buy some pipe to weld the cab up nice and square before I start cutting it up(all over). Thanks for the info, it looks good
71 GMC lwb
56 Big window swb
93 GMC Sonoma (dd)
Old 10-09-2007, 08:20 PM   #6
Tigman
Looks whats lurking under your inner sheet metal!!
Mark
Old 10-10-2007, 02:24 AM   #7
gringoloco
A guy with a truck
gringoloco's Avatar
WOW! You really tore into that thing didn't ya? Did you lose a lot of structural rigidity when the inner structure came out? Are the inner panels still good and are you planning on putting them back in?
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 10-10-2007, 02:49 AM   #8
earl87gta
earl87gta's Avatar
I think I would have got a new cab . its looking good. Thats a lot of rust hidden under there.
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
Old 10-10-2007, 12:05 PM   #9
Tigman
I welded in cross bracing before cutting out anything! The cab had a decent floor but he cowl was eat up. I gonna fab in a whole new cowl without the vents. And use Specialty Power Windows street rod wiper unit. After blasting it was in pretty good shape. Just surface rust. I'm going to reinstall all the interior metal after welding in the front patch panel where the visors go. I'll post some pics as I go along!
Mark
fabshopinc.com
Old 10-10-2007, 12:07 PM   #10
caminokid
Chevy nut
caminokid's Avatar
man I am so glad I dont have the money lady problem! I got lucky this time and got a woman that never tells me NO!
84 Chevy Custom Deluxe 1/2 Ton Named Fade To Black II
"Remember kids there is NO replacement for displacement!"
caminokid is offline   Reply With Quote
