Old 10-06-2007, 08:34 PM   #1
pkbinplano
pkbinplano
pkbinplano's Avatar
It's all on and I'll never do it again
Don't want to, don't have to and you can't make me. Total front end rebuild. Upper/lower control arm bushings, upper/lower ball joints, inner/outer tie rods, idler arm, pitman arm, shocks, brakes, brake lines, bearings and seals, all thats left tomorrow is put rotors and brake shoes on, flush and bleed system and get it alligned. Total cost minus allingnment $780 . NTB wanted $1400 just for upper/lower control arm bushings.
http://www.picturetrail.com/gallery/...7496&members=1
84 chevy silverado aka The Bananna Boat
pkbinplano is offline   Reply With Quote
Old 10-06-2007, 09:00 PM   #2
77-383 Step
Re: It's all on and I'll never do it again
Thats a lot of work. Did it earlier this year. Congratulations.
77-383 Step is offline   Reply With Quote
Old 10-06-2007, 09:24 PM   #3
Yankeelights
Yankeelights's Avatar
Way to go man ... should be good for another 30 years!
Yankeelights is offline   Reply With Quote
Old 10-06-2007, 09:28 PM   #4
killthewabbit
Spear and magic helmet!
killthewabbit's Avatar
Never, huh? 30 years from now they're gonna want even more than $1400, you know...
-- Will
killthewabbit is offline   Reply With Quote
Old 10-06-2007, 09:45 PM   #5
pkbinplano
pkbinplano
pkbinplano's Avatar
77 step, what color is your ride ? I'll keep an eye out for you
Old 10-07-2007, 03:42 AM   #6
Prong
I feel your pain. I've done the 4wd version (tie rods, drag link, U/L Ball joints, Axle U- Joints, leaf spring bushings) twice. Once on one of my current trucks and the second on a previous truck that I owned. It was tedious work but it saved me a lot of $$.
Prong is offline   Reply With Quote
Old 10-07-2007, 04:18 AM   #7
knightlife
Dark Heart Motorsports
knightlife's Avatar
yeesh...Im gonna have to talk to the wifey if I wanna do anthing like that...gotta have approval ya know? lol
How Deep Can YOU Bleed..?
1985 Chevy Blazer K5- 6.2 N/A, 400 turbo trans CUCV, 12v converted... a new chapter
2005 GMC Sierra Crew Cab 6.0 powwwaa!!! custom jumpseat install w/ captain seats, Hypertech tuner, MSD Blaster Coils, CB and twin antenna's, all electric interior, touch screen in dash. custom center console, with jump seat replacing original console. 1500 HD!
knightlife is offline   Reply With Quote
Old 10-07-2007, 09:06 AM   #8
jermasaurus
jermasaurus's Avatar
That truck is gonna ride better than when it was new!
Eventually I'm gonna have to do my front end too. I'm sure the results are well worth the work.
79 Jimmy slammed AKA James Down
jermasaurus is offline   Reply With Quote
Old 10-07-2007, 09:35 AM   #9
koreric75
83C10SWB
koreric75's Avatar
Question Re: It's all on and I'll never do it again
just curious, did you have to do anything with the steering box itself?? Mine has started leaking ps fluid and the steering is not tight like it used to be, alot more play in the steering that i like.
Koreric75
2003 Suburban Z-71 4x4
5.3L
83 C10 SWB FOR SALE
350ci/700Raptor Jr
Picture&Progress Page
koreric75 is offline   Reply With Quote
Old 10-07-2007, 10:02 AM   #10
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
there's usually an adjustment on top with a lock nut, that you can take some of the slop out. release the locknut and turn the center post slightly to tighten.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 10-07-2007, 11:36 AM   #11
Restrorob
The One And Only !!!
Restrorob's Avatar
Pay attention to the above word, If tightened too much the steering wheel will spin in either direction soon as the engine fires.
So, Keep your hands off/away from the steering wheel to prevent broken fingers for the first fire-up after adjustment.
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 10-07-2007, 11:52 AM   #12
koreric75
83C10SWB
koreric75's Avatar
Thanks for the warning, will try to take some of the slop out, my haynes manual got wet after the heater core leak so i need to get a new one to help on stuff like this...lol.
Koreric75
5.3L
83 C10 SWB FOR SALE
350ci/700Raptor Jr
Old 10-07-2007, 12:06 PM   #13
C&C Chevy
C&C Chevy's Avatar
Don't suppose you took alot of pictures? Have to do this rebuild in the winter some time..
Robert
Current:
1986 SWB Silverado 4.3 / TH400
Past:
1985 SWB Silverado 305 / TH350 - sold 1995
1987 1/2 ton Silverado - FI 350 / 700R4 sold 2007
C&C Chevy is offline   Reply With Quote
Old 10-07-2007, 01:07 PM   #14
pkbinplano
pkbinplano
pkbinplano's Avatar
just took it for a drive. Rides like a Caddy again. Kicker is the wheel is straight, and it doesn't pull to one side. Guess I did my measurements correct. Just dropped it off for allignment.
Old 10-07-2007, 07:15 PM   #15
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
It's not hard with the right tools.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 10-07-2007, 07:49 PM   #16
pkbinplano
pkbinplano
pkbinplano's Avatar
what special tools did you use that would make things easier ? Maybe a pneumatic chisler
Old 10-07-2007, 09:53 PM   #17
Restrorob
Restrorob's Avatar
I rebuilt my whole front end also before I decided to go ahead with the body-off.
My special tools were a 6" bench vice, 3/4" drive socket set and a BFH. But being in the repair biz I knew how/what needed to be done.
93 Jeep XJ
88 Buick La Sabra
Toys;
97 GMC Ext. Cab
Old 10-08-2007, 07:49 PM   #18
streetstar
streetstar's Avatar
I suppose you mean for the ball joint rivets ---- i drilled out the center of the rivet head on mine and then hit the base of the rivets with an air hamer and chisel bit ---- drilling it means the air chisel has to go through a lot less metal to knock 'em off
I'm definitely not a pro though -- even with the power tools - the job sucked
streetstar is offline   Reply With Quote
Old 10-08-2007, 09:06 PM   #19
pkbinplano
pkbinplano
pkbinplano's Avatar
yup. The ball joint press I rented helped alot, along with a electric impact I bought awhile back. Best investment ever.
Old 10-08-2007, 11:45 PM   #20
BaddBusa2005
BaddBusa2005's Avatar
I am getting ready to do all the same thing, but with some aftermarket lower a-arms and spindles. Let us know how the truck feels compared to how it was
1981 Custom Deeluxe SWB 5.3/4L60e 3.73 and Auburn. Mustang Dyno 265hp/258tq
BaddBusa2005 is offline   Reply With Quote
Old 10-09-2007, 06:51 AM   #21
pkbinplano
pkbinplano
pkbinplano's Avatar
drives like a Caddy again. Ultra quiet over RR tracks.
Old 10-09-2007, 10:17 AM   #22
Ivan D.
glamoros piece o' lowlife
Ivan D.'s Avatar
I rebuilt the front end of my Lincoln last summer, using all ultra-heavy-duty DANA parts from NAPA - ran me a bit under $500, but I had a serious discount at the local store. Now I wanna rebuild the truck too, but I got tuition to pay and not enough time to fiddle with rusty hardware and other joys of that sort - I already have all new brakes and hoses and lines tho, so maybe I'll just get a set of control arms off a junker truck or somethnig and rebuild them on my free time and then just swap them in over an evening after work...
The more I drink, the more I drink, the more I drink...
diesel, reg cab, long bed, 4 across the rear, single stack, wooden stakes, and lotsa lights - the Hay Express
Ivan D. is offline   Reply With Quote
