Welder
looking into buying a welder, I have never done any welding but want to take a class at the local community college on it, I just want to be able to weld my own parts on. Can anybody suggest what type of welder I would need and what brand is good. I looked at the Hobarts at tractor supply yesterday, but not sure if I need wire, mig, or what.
Used Register
Re: Welder
Wire (MIG) is likely to be the most versitle and easiest to pick up. If you are going a class to assist, which is a great idea, do that first, then buy the welder.
Over in the body and paint forum there is a sticky about welders and lots of good suggestions/opinion. Helped plenty when I got mine, which by the way, is a Hobart Handler 187. In general, don't cheap out. Buy the best you can afford. On welders, as on many things, price does reflect quality. Quality always costs, but you can also get some expensive crap. Herb |
Re: Welder
Buy the best welder you can offord. Wire feed is pretty forgiving. Spring for the shielding gas too. Hobarts are decent welders. They are made by Miller which many consider to be the best. I have a Lincoln. Those are probably the top 3 names.
Questionable
Re: Welder
go to the paint and body forum here.
there is an entire thread dedicated to welders, it is just underneath the announcements: http://67-72chevytrucks.com/vboard/f...splay.php?f=16 it helps to keep all of the welder questons in one thread, so i encourage you to use that thread (read it first) for any questions you may have.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
Re: Welder
I bought a Miller 180...and it is all I need for this truck building hobby!
Alex 1971 Lil' Red 350 SBC 700R4 |
![]() Join Date: Mar 2007
Re: Welder
Great idea on taking the class at the community college. I took one last year after buying my welder, and the class has paid for itself many times over. I bought the Lincoln weldpak 175 from Home Depot, and it has worked great on every project I have tackled so far. Everything from shaving my firewall to building one of Rockcrawlin's tip'n'flip cab dollies. Rent a C25 tank from a local dealer, and buy a larger spool of wire and you're set. My first tank and spool lasted almost a year, and I have done a lot of welding with it.
![]() Join Date: Nov 2006
Re: Welder
Buy a miller 250 amp, 220 volt and you,ll be good from the thinnest to 1/2 plate. you,ll be glad you did.
bob
I BELIEVE IN JOHN 3:16 Last edited by BCOWANWHEELS; 10-08-2007 at 09:42 PM. |
Re: Welder
I think i am going to go with the Hobart 187 mig welder...I feel like it may be the best bang for the buck....also did you buy a accesory kit...what all will I need?
4 eyed fever
Re: Welder
I just bought a Lincoln last week. Bought the bottle to go with it, but also flux core wire for outdoor windy ranch repairs. It comes with interchangable rollers to use either type. Haven't even had time to strike an arc yet.
1971 GMC 2500 4x4 1972 GMC Sierra Grande 1/2 t 4x4-#1 son's truck. Recently completed resto. 4 YO daughter," Daddy, I like your truck better than Mom's." (2000 F350-ranch truck) Smart kid!! |
#10 | |
Used Register
Re: Welder
You may also want to pick up a MIG combo tool (wire cutter, tip pliers, and tip cleaner combined) and maybe some spare tips (while you're learning). Herb |
Active Member
![]() Join Date: Jul 2007
Re: Welder
Since we're already talking about welders, I have a question.
Since I already have an arc welder but just need a mig for sheet metal, which size mig welder would be okay? Oh, one more thing, what size tank (argon) are you all buying or renting? Sorry for hijack... |
#12 | |
Used Register
Re: Welder
#13 |
Re: Welder
The Lincoln MIG 135 (and the 140)works like charm. Sheet metal, mufflers, spot welding, even a frame. I learned to use it myself. It is 110v (20 amp breaker reccomended). If you are restoring a car or like to do shop tasks this is a good choice. Also, shielding gas (Argon C02 mix) is a must for clean beautiful welds.
#14 |
Re: Welder
I think GMAW or FCAW (self shielded wire) its good option
