Old 10-03-2002, 11:14 AM   #1
Yukon Jack
Post Whore
Yukon Jack's Avatar
Ideas on my exhaust placement
When I get the 454 in, I am going to rework my exhaust. I've got Dynomax headers and 2 1/2" Dynomax Ultra Flow mufflers. I will use 2 1/2" exhuast pipes with an h-pipe.
I don't like the present placement of the exhaust tip, asthestically and because it is not very protected.
I'd like some suggestions on different placement.
This truck is not a daily driver and I don't mind if it is loud. I don't want it like it is now, cause sooner or later I'm gonna back or drive over something and bend it.
Here's how the present setup exits the truck.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 10-03-2002, 11:30 AM   #2
barn9
Half a bubble off!
barn9's Avatar
I would say go stright back from the axle bend along the side of the framework for your trailer hitch with a little downturn at the end to point that exhaust out from under the end of the bed. Speaking of beds, don't forget the rhino woman, he-hee!
Just call me LB.
'71 Cheyenne, 402BB, hauls blondes, brunettes, or redheads.
barn9 is offline   Reply With Quote
Old 10-03-2002, 11:52 AM   #3
HotRod929
HotRod929's Avatar
Location: Bondurant, IA but in Worcester, MA for school
Open headers baby!!!
HotRod
1970 Chevy C-20
350 V-8
Turbo 350 w/ shift kit
Dana 60 w/ 4.10 gears AND Powr-Loc POSI
New Additions:
Summit Headers
135amp alternator
Proform HEI
Edelbrock 1406 600cfm carb
Sunpro Tach
Powr-Loc POSI
Edelbrock Performer RPM Intake
MSD 6A Ignition Box
AIM: HotRod929
Visit My Site: http://1970chevy.netfirms.com/
HotRod929 is offline   Reply With Quote
Old 10-03-2002, 12:18 PM   #4
Lippyp
English Chevy Owner
Lippyp's Avatar
Can't see the back properly but how about keeping them up real high and taking them out through a cut-out in the rear plate of the bed, maybe together in the middle a bit like the Lotus Elise sports car. They'll be protected by the tow hitch and tucked up out of the way.
Phil
'67 C10 long fleet.
350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon
2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission
Lippyp is offline   Reply With Quote
Old 10-03-2002, 12:25 PM   #5
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
If you don't care how loud it is do a couple turn downs right after the mufflers.Or run it out just in front of the rear wheels.With that AWSOME looking flatbed on there I doubt you'd have a problem with fumes.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 10-03-2002, 12:31 PM   #6
Yukon Jack
Post Whore
Yukon Jack's Avatar
Here's a pic of the hitch.
Old 10-03-2002, 01:43 PM   #7
BobbyK
BobbyK's Avatar
I've also seen the pipes run straight out the back,along each side of the hitch.
Old 10-03-2002, 02:25 PM   #8
palallin
Mine currently turn out like yours but ahead of the rear wheels; I haven't hit anything with them yet, and mine isn't lifted any.
Of course, I plan to switch to stacks; do that, and you'll need to worry about low-hanging wires, but not trail obstacles
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt.
palallin is offline   Reply With Quote
Old 10-03-2002, 08:12 PM   #9
Ackattack
Ackattack's Avatar
I'd go with in front of the rear wheels. That's the way mine is, but mine is strictly street driven.
Ackattack is offline   Reply With Quote
Old 10-04-2002, 05:43 AM   #10
Lippyp
English Chevy Owner
Lippyp's Avatar
Having seen the back I'd definitely be different and take a tank cutter to that chequer plate either side of the license plate and cut two round holes, maybe sleeve them with a short length of pipe slightly larger than your exhausts and run them through the plate. They'll be well protected and nice and high out of the way when in water or backing up off road.
Phil
'67 C10 long fleet.
Old 10-04-2002, 06:23 AM   #11
BobbyK
BobbyK's Avatar
That's a cool idea!
Old 10-04-2002, 08:20 AM   #12
Newby 69 GMC
LippyP's idea is cool.
A couple of chrome tips sticking through that checker plate would look awsome!
MY $0.02. (CDN currency so basically worthless in USA)
Trevor
Newby 69 GMC
Also own
88 4X4 Toyota P/U
01 Toyota RAV 4
Newby 69 GMC is offline   Reply With Quote
Old 10-04-2002, 08:34 AM   #13
Mike C
Mike C's Avatar
I'd think about turn downs PAST the rear axle. This is not ideal, but will look OK. Actually, I like where you have it the way you have it as the best spot, but aesthetically it is lacking with your flat bed... NEVER point exhaust straight out the back in a 4x4 (any truck IMO) when you get it in the mud and you have to slam it forward and backwards to get out, you pack the exhaust full of mud and water, killing the motor. Snow applies here as well. "Real 4x4 don't run chrome baloneys" Also, straight out the back will make a sooty mess of your trailer or your load if you have a flat bed. Do you have enough room to run between the shackle reversal and the trailer hitch?
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 10-04-2002, 08:57 AM   #14
Newby 69 GMC
Mike C I agree with what you said if he was going to put it down by the trailer hitch but up in the bed? How deep of mud are you going through?
As for the tips, I know I didn't explain but I meant a couple of down swept tips to help with the carbon thing.
And I think that chome looks good on 4X4s. (I know cheap stuff rusts)
Trevor
Newby 69 GMC
Also own
88 4X4 Toyota P/U
01 Toyota RAV 4
Old 10-04-2002, 09:19 AM   #15
crazy longhorn
Fabricate till you "puke"
It would sound good with a set of stacks running up behind the cab,& you wouldnt have to worry about the mud! I have plans to run my ex like that on the old flatbed. I dont remember if your bed has a hoist or not, but I plan to cut 2 holes in the floor of theflatbed, & run the stacks up & hang em on the headache rack. I wont be doing any chrome,just 3" aluminized pipe with rain caps. good luck......crazy longhorn
crazy longhorn is offline   Reply With Quote
Old 10-04-2002, 01:33 PM   #16
Burlinator
Just Another Crazy Canuck
Burlinator's Avatar
fenderwell headers and stacks!!!!!!!!!!!!!
1985 454/465/205, 38.5x11-16BOGGERS
soon to be installed: 14bDETROIT,Edelbrock Performer cam,intake and valve springs,Comp roller tips,MSD HEI
Burlinator is offline   Reply With Quote
Old 10-04-2002, 02:16 PM   #17
Yukon Jack
Post Whore
Yukon Jack's Avatar
I had a buddy with stacks on his mid 90's 1 ton flatbed and man it gave me such a headache and that was with a stock engine. Stacks are out
Mike C - I don't think there is enough clearance to go between the shackle flip and the hitch but I will take a look.
I'm leaning towards going past the rear axle, tucked up high with a slight turn down.
Old 10-04-2002, 07:25 PM   #18
crazy longhorn
I helped install a set of stacks on a Ferd when I was down at the muffler shop,that 351 W sounded awsome........but i didnt ride in it. That might be a thing to check out before I do the stacks on mine! They sure sounded good goin down the road,but who needes a headache?
