Old 10-07-2007, 06:09 PM   #1
The Big Green
Couple questions on bagging a 67
I have a 1967 chevy swb and I want to bag it. First of all I want to be able to drive it on a regular basis. I don't really want to drag frame I want it more for a good ride quality but I'm sure I will end up wanting to drag it later on. I need the exhaust to tuck and not hang down like it is now but I don't know how that can be done. I don't really want a $4000 bag setup but something I can upgrade later on. I would appreciate any help.
The Big Green is offline   Reply With Quote
Old 10-07-2007, 06:53 PM   #2
hotrodhomi
hotrodhomi's Avatar
Re: Couple questions on bagging a 67
What is the question?
'72 2wd blazer, bagged w/ watts link & EDC
'72 C10 "Lowered Farm Truck" STOLEN 5-18-11
'66 impala ht
hotrodhomi is offline   Reply With Quote
Old 10-07-2007, 09:26 PM   #3
The Big Green
I read that again and I got lost so let me refrase that. My first question is that my 2 1/2 exhaust coing off my headers turns down right behind cab and has a couple 2 chamber flows. How can I hide this exhaust? I don't like seeing it when you look at the truck from the side and see everything. I want to bag but first I need to find a way to move the pipes out of the way.
Old 10-07-2007, 09:42 PM   #4
jlaird
jlaird's Avatar
well depending on what headers you have, you may need 3/4 length or shortys. The only other thing you have to do if you want the exhaust to go further than the back of the cab is to cut holes in the crossmember. The easier way out though is to get the extreme drop crossmember at ece.
CPP has one too:
jlaird is offline   Reply With Quote
Old 10-08-2007, 11:43 AM   #5
Inverter
Inverter's Avatar
Get the "Sanderson" streetrod headers,modify crossmember like the above post,run new pipe and get the correct inlet/outlet config. on your chambered muffs. DONE!
Inverter is offline   Reply With Quote
Old 10-08-2007, 12:37 PM   #6
SCOTI
SCOTI's Avatar
There are several manufacturers that offer "3/4 length" headers. People have used F-body, A-body, & street-rod style headers w/good clearance. Another option is the old 60's ram horn cast manifolds.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-08-2007, 08:25 PM   #7
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
like these?
http://cgi.ebay.com/ebaymotors/SANDE...QQcmdZViewItem
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 10-09-2007, 10:50 AM   #8
The Big Green
Thanks guys this helps me out alot and when I get these pipes out of the way I can start bagging it.
Can anyone point me in the right direction on bagging. I know as far as compressors and switches. I want it for ride quality so whats the easiest way of bagging my 67 chevy? I want Slam bags but what about a good monster notch and 4-link? I don't really want to get 3 grand in parts right now I'm a poor guy with to many toys. I want to start getting the bags and stuff though. What size Slam bags would I need?
Thanks in advance
Old 10-09-2007, 01:24 PM   #9
SCOTI
SCOTI's Avatar
Thanks in advance
ART or KP Components are good places to start for kits for people that aren't familiar w/all the pro's/con's of putting their own system together. Suicide Doors is a good place for piecing your own 'kit' together.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-10-2007, 12:29 AM   #10
IvelDesigns
Commander Taco Bello
IvelDesigns's Avatar
Cheap baggin' 101
Plan A
$300 - 4 Bags - Slam Specialties RE-7's are a good fit
$20 - 25' of 3/8" air line
$30ish - Some brass fittings (every setup is different, so i'm not gonna guess what you need)
$10 - 4 shrader valves (tire filler valves... you can get them at NAPA)
$50 - Cups and Plates for the fronts
$410 - Total
Plan B
Everything in Plan A, minus the shrader valves
$120 - New Shocks
$220 - 8 3/8" SMC valves
$220 - Vlair Compressor
$20 - 10 switch box
$50 - 5 gallon tank
$20 - more 3/8" line
$60 - more fittings
$100 - Adjustable Panhard Bar
$1120 - Total
Plan C
Everything in Plan B
$100 - Guages
$300 - 2.5" drop spindles
$100 - Bolt in C-Notch
$100 - new ball joints
$75 - new tie rod ends
$1895 - Total
Couple things to note. if you have a split drive shaft, you can flip the carrier bearing mount to get a pretty good pinion angle. while you have thins apart, you might as well replace trailing arm bushings, and U-joints. Also, a set of 2.5" blocks wouldn't hurt. That means new U-bolts.
That setup is pretty much what i did to my 69. I drive it daily (until it snows) and have had no issues.
Oh, i forgot to mention that almost everything listed above can be found at *****************. everything else can be picked up from ECE or NAPA.
good luck!
IvelDesigns is offline   Reply With Quote
Old 10-10-2007, 09:30 AM   #11
hotrodhomi
hotrodhomi's Avatar
Why do you need an adjustable panhard bar?
'66 impala ht
Old 10-10-2007, 09:54 AM   #12
SCOTI
SCOTI's Avatar
As the truck drops, the rear shifts over & the stock bar is no longer the correct length. You could technically modify the stock bar to work for ride height, but once you dump the air, the location of the stock short bar will cause the rear to shift more.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-10-2007, 12:23 PM   #13
IvelDesigns
The other option would be a wishbone type setup where you build a cross member behind your axle that has two arms that connect to the pumpkin in a V. This would prevent your axle from moving side to side as well.
There are also many other options too, each way more expensive than an adjustable panhard bar.
