1970 Rear End Question
How do I tell if the rearend in my 70 is the wide or narrow one? I want to convert to 5 lugs but Im not 100% sure what axles i need. Is there A way to I.D. it? Can you get conversion axles for either one? Any help is appreciated.
1970 SWB Build |
![]() Join Date: Feb 2004
Re: 1970 Rear End Question
What do you mean by wide or narrow one, There is a difference between 67-72 rear ends and 73 and up rear ends. The 73 and up are longer (the axle half shafts).
On the rear end near the bell housing there should be some numbers, clean off the rear end and get those numbers and someone on here will chime in with the answers that you seek
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
In mid 1970 model year, they went to the longer rear. 57 1/2" compared to the older 56".
1997 GMC Sierra Ext 1965 Mustang |
where do you measure from
1970 SWB Build |
I have a radical idea!
Backing plate to backing plate.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
The only numbers I could find were on each side of the pumkin on the front of the axle. On the Drivers side it has "GM53" and on the passenger side "NF389683" are these th right ones to ID it. I measured it and I think its 57.5'' backing plate to backing plate. Are these the correct numbers, and if so, Can anyone ID it? Thanks
1970 SWB Build |
67-72 parts collector,…
![]() Join Date: Nov 2002
I believe you should be able to use stock '71-'72 axles in your '70 housing since it's the wider version.
