10-08-2007, 09:42 AM | #1 |
Pictures of my now clean motor
Here are some pictures of my motor all cleaned up in my 68 c-10. It is a 307 and I just got done installing a eld. 600, eld. performer manifold, 93 s-10 serp. setup, points eliminator and a new timing chain. I will snap some more pictures of the finshed product as these are in process pictures.
68 Chevy C-10 custom, 350,4bbl, serp belt swap, th400, 5 lug disk conversion, added honda seats and factory tach. 71 Gremlin X, 360, t-5, 8 3/4 rear, and dodge dakota seats. 82 Spirit, 4.0,ax-15, 8.8 rear and sti bucket seats |
10-08-2007, 09:47 AM | #2 |
I have a radical idea!
Re: Pictures of my now clean motor
Looks great! Where did you get the clear section for the radiator hose.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! Last edited by 67_C-30; 10-08-2007 at 09:48 AM. |
10-08-2007, 10:15 AM | #3 |
upgrading to an older model
PRETTY!!! I've got one on an engine stand that needs cleaning, whats the best way? Unless, of course, you want to come over and do it?!?
68 stepside, short-box, multi-colored (for now) |
10-08-2007, 10:34 AM | #4 | ||
And just so you can share in my stressfull evening, I was up all last night trying to get it to run! I had good luck with that after I gave the petronix a full 12 volts. I had it going to the coil and it would start then die. Upon reading the instructions I read the part that if you vehicle had a balast resitor or resistor wire (that is what our trucks have) it must have 12v from the ignition. After I did that it ran nice but the right side Ims screw does not change how it runs and it has a surge issue going down the road. It also has a little vibe at idle, what do you guys have your idle set at? I am sure I will get these last items fixed but if anyone had any ideas I would be glad to hear them.
10-11-2007, 05:46 PM | #5 |
You should add a bigger air cleaner so the engine can breath properly. Looks good
There is no replacement for displacement! |
10-11-2007, 06:25 PM | #6 | |
'78 GMC. I love the look of it!
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
10-11-2007, 07:32 PM | #7 |
Tot Roddin'
Looks great!
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
10-11-2007, 07:35 PM | #8 |
Between Trucks...
That serpentine setup looks sharp...
Beat it to fit, Paint it to match... |
10-11-2007, 09:35 PM | #9 | |
HERE.......Somewhere
Current rides: 2013 Hyundai elantra gt DD 1995 camaro my first crush lmao Was: 1970 with a 350 4barrel and 288 horses Classics make it possible! |
10-11-2007, 09:46 PM | #10 |
Problem Child
M/T is the brand of valve covers Mickey Thompson
1972 gmc sierra grande 350/350 a/c soon`to get a new 350 I Survived Norwood |
10-11-2007, 09:48 PM | #11 |
Thanks for all of the kind remarks! I will get some finshed pictures tomorrow and post them up. I have been driving the truck a little and so far have been very happy how the engine came out. The M/T stands for Mickey Thompson
as for as I know. I wanted finned covers and my friend gave them to me for free!
10-11-2007, 10:19 PM | #12 |
HEY 68c-10, IT LOOKS GREAT. GET YOU SOME ALUMINUM BRIGHTNER AND USE RUBBER GLOVES. TAKE A SPONGE AND DAB IT ON THE ALTERNATOR TO BRIGHTEN IT UP!
Freedom is never more than one generation away from extinction. We didn't pass it to our children in the bloodstream. It must be fought for, protected, and handed on for them to do the same.... Ronald Reagan |
10-12-2007, 01:19 AM | #13 |
Hey that's pretty cool, was it very difficult to put together and swap out?
What did that set up set you back?
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
10-12-2007, 08:10 AM | #14 |
Looks good cleaned up nice.
Earl 68 2500 4x4 GMC Burb |
10-12-2007, 08:30 AM | #15 |
The cost broke down like so
Brakets, pullys, power steering pump, ac compressor and alt - $50.00 A/c delete or bypass pulley - $31.00 New power steering hose for a 1968 chevy - $16.00 Stainless 90 for the power steering hose to not hit the block - free Wiring kit to convert to the new alternator - $20.00 Water pump for 93 s-10 with a 4.3 - $17.00 Total $134.00 not including one idle pully I replaced do to me not recalling the cost. It was as easy as bolting on the brackets and connecting some plugs. I had to leave out one bolt on the pass side due to my head not having the bolt hole required. This is near the intake and there is a brace that goes from that side to a water pump bolt so I think it will be fine. The power steering was simple due to the fact that I switched fittings on the pump. The stock pump is double flare and the new one is o-ring so I simply unscrewed the fitting out of the old pump and put in the new one no problems. The replacement hose I got came with a brass adapter which would have put the hose into my block due to the pump being tucked in tighter. To get around that I had my freind bend up a short 90 with the correct fittings and hooked it up. I am very happy with it and love that I can crank the steering wheel and not hear the chirp of the belt! On to some more pictures!
68 Chevy C-10 custom, 350,4bbl, serp belt swap, th400, 5 lug disk conversion, added honda seats and factory tach. 71 Gremlin X, 360, t-5, 8 3/4 rear, and dodge dakota seats. 82 Spirit, 4.0,ax-15, 8.8 rear and sti bucket seats Last edited by 68c-10; 10-12-2007 at 08:41 AM. |
10-12-2007, 08:54 AM | #16 | |
www.killerglass.com |
10-12-2007, 12:39 PM | #17 |
The master of disaster
Thats a nice set up and the work you did and thought of i have never seen done down here on any big old truck so great job man.
hey 67_C_30 is me or is that a set of dirt track valve covers from smiley's the blk ones |
