Old 10-08-2007, 10:15 AM   #1
Alex Hayley
powder coating oven
To those that have an oven for powder coating in the garage, what amperage of circuit breaker are you using for this oven?
Alex Hayley is offline   Reply With Quote
Old 10-08-2007, 10:56 AM   #2
70GMCer
70GMCer's Avatar
Re: powder coating oven
I assume that you're speaking of a household oven. I have a double pole 30 Amp. You should check the numbers on the back of your oven to see what the breaker size is recommended. Most ovens are 30 or 40 amp 240 volt
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 10-08-2007, 02:45 PM   #3
Alex Hayley
I do have a household oven. I have looked everywhere on the oven for the recommended breaker amperage but can find nothing. Perhaps I don't know exactly where or what to look for. It is an Amana model #ARR630WW if, for some odd reason, someone happens to know the breaker amperage. I have a 20 amp circuit in my garage for a plasma cutter that I might swap a 30 amp breaker into...I will also verify the wire can handle that amperage.
Old 10-08-2007, 03:31 PM   #4
70GMCer
70GMCer's Avatar
Try lifting up the top of the stove and look under there. I'll bet a 30 amp will work for you. A 20 amp might just be too low. Also, my wire running to my garage is 8/3 size wire. Now when I use this oven, (I haven't tried it yet) I don't think I will be able to use anything else at the same time, except maybe the lights. Just go to Home Depot or Lowes and get a 30 amp., and try it. Worst that would happen, is that it will just trip it. Or for that matter, just try the 20 amp. first and see what happens.
1997 GMC Sierra Ext
1965 Mustang
Old 10-09-2007, 11:58 AM   #5
Putter
More Cowbell....
Putter's Avatar
30 amp....house oven (Kenmore)!!!
It sure somes in handy....powder coating various brackets and enjoying a fresh baked pizza at the same time. Mmmmmmm.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket
Putter is offline   Reply With Quote
Old 10-09-2007, 12:16 PM   #6
Luvlegs
Luvlegs's Avatar
Try the 20 first - if it does trip, don't try a 30 until you know what wire size you do have going to it. if it can't pop the 30, you don't want the wires burning up.
"A cat will almost always blink when hit between the eyes with a ball peen hammer"
(you don't always have to state the obvious)
Wear your PPE! You can eat with false teeth but you can't see with a false eye.
1959 Studebaker Silverhawk 350/400
1972 C10 L6 3OTT
2005 F350 - Built - whew!
Luvlegs is offline   Reply With Quote
Old 10-09-2007, 12:20 PM   #7
70GMCer
70GMCer's Avatar
Not to mention heating up the garage in the winter time......
1997 GMC Sierra Ext
1965 Mustang
Old 10-09-2007, 12:21 PM   #8
70GMCer
70GMCer's Avatar
Just finished hooking mine up and testing with a 30 amp. Works great at 400 degrees and breaker doesn't trip.......
1997 GMC Sierra Ext
1965 Mustang
