Junior Member
72 big block power steering question
If I use a long water pump set up can I use a pump and brackets off a donor vehicle or do I have to use a factory 72 set up?
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
Re: 72 big block power steering question
To use the stock PS pump and bracket you will need a short water pump.
1972 Cheyenne C10 Unrestored Original-3 Owner-RUST FREE Texas Truck Big Block-TH400-PS-PB-AC-AM/FM Radio |
Junior Member
I am wanting to use a long set up for both water pump and power steering if the p/s will fit with the frame.
Try Alan Grove brackets. When I installed my Vintage Air kit it came with a compressor bracket from here and it fits and looks factory. Here is there web address. Maybe they have something that will work for you.
http://www.alangrovecomponents.com/index.htm Brian
p/s will fit in the frame with no problem. You will need the brackets and pullies off a long water pump setup.
72 CHEYENNE 10 SUPER 468/400/3.73 |
Junior Member
Cool. Does anyone have pics of a big block long water pump and power steering on a 72?
Im running lwp parts on my 69. Just use the brackets for the 73-up bb trucks. If you dont have a pump yet, get the later pump too. It will save a little of the hassle of the return tube...
Junior Member
Thanks CORN. I have all the lwp crome pulleys, aluminum water pump and crome lwp alternator brackets and was not sure if the p/s pump would work. Good news.
