Building Dreams out of Dimes!
Sound deadener alternative
Hey folks! I recently took the carpet out of my old truck I bought because it smelled something like greasey wool and rat urine.
![]() http://www.lowes.com/lowes/lkn?actio...025&lpage=none I was just going to use some spray adhesive and stick it to the back of the carpet. I think it will work just as good. I will also be using that foil insulation tape. I'm thinking I may double it up as well. Like put one layer on the carpet and another layer on the floor itself. Well do you all think it will work ok? I am broke so that is why I'm not just buying new stuff if anyone is wondering. Thanks for your time! |
Re: Sound deadener alternative
OH I forgot to mention. I am keeping that hard black insulated stuff in the truck. I didn't remove it because it is glued really good to the floor. I only removed the insulation stuff that is in front of the seat, you know where your feet go. That will be the part I am replacing with the product I showed you in the link. thanks again!
This is the adhesive I will be using along with some gorilla glue. http://solutions.3m.com/wps/portal/3...er-77/Super77/ Last edited by Hazieview; 10-08-2007 at 05:54 PM. |
It looks like a good heat barrier, but I would be a little leery about its sound deadening qualities. You never really know til you give it a try. I know you said you were broke, but here is an alternative in case you come into an inheritance or something.
![]() 2012 Silverado LT 1500, 5.3, 6 speed auto '86 SWB C-10 Silverado |
Dark Heart Motorsports
thank you crawdad...Ive been looking for a cheap alternative as well...Im not broke, but I am stingy
How Deep Can YOU Bleed..? 1985 Chevy Blazer K5- 6.2 N/A, 400 turbo trans CUCV, 12v converted... a new chapter 2005 GMC Sierra Crew Cab 6.0 powwwaa!!! custom jumpseat install w/ captain seats, Hypertech tuner, MSD Blaster Coils, CB and twin antenna's, all electric interior, touch screen in dash. custom center console, with jump seat replacing original console. 1500 HD! |
What about this stuff? Anyone use it? Any good?
http://www.malloryracing.com/Product...&minselection= |
