Old 10-08-2007, 10:06 PM   #1
2bits
2bits's Avatar
Setting valves different on an inline 6 vs a v8?
My rebuilder said that you don't set the valves the same way... (loosen 'til it clatters, tighten 'til it goes away, then 1 more half turn). Can anyone confirm?
_______________
Thomas
'78 Silverado
'74 Monte Carlo
'47 Teardrop Trailer
East Texas Classics Local Club
2bits is offline   Reply With Quote
Old 10-08-2007, 10:19 PM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: Setting valves different on an inline 6 vs a v8?
I've always done mine the same on 6 cylinder and 8 cylinder. Haven't had any problems yet.
On the last overhaul I did I went 3/4 turn instead of a full turn, though.
68gmsee is offline   Reply With Quote
Old 10-08-2007, 10:22 PM   #3
67_C-30
I have a radical idea!
67_C-30's Avatar
Unless it's a got a solid cam (doubtful) they will be set the same way as a V8 with a hydraulic cam. It's better to get the lash out, and go 1/4 turn. There's no need to a go a 1/2 turn.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 10-08-2007, 10:42 PM   #4
Boog
laying low
Boog's Avatar
1/2 to 3/4 turn is the norm regardless of what a repair manual says. Always works for me.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 10-08-2007, 11:04 PM   #5
67_C-30
67_C-30's Avatar
You can run them that way, but the more you tighten the rocker, the quicker the valves will float at high rpm. Now on a L-6, this is a moot point, but on any kind of street performance engine you should go 1/4 turn MAX. On bracket race cars with hyd cams, the norm is an 1/8 turn. I know this is not a race or performance engine, but same rules apply.
Will it run fine at 1/2 turn? Sure, but there's no need to do it. The more you crank down on it, the greater the chance of wiping out a lobe. I have run bone stock engines for 200,000+ miles with no need for re-adjustment.
My trucks
Old 10-09-2007, 03:45 PM   #6
2bits
2bits's Avatar
I had always heard 1/2 turn but I have no experience. Why is it a moot point for an L6 though? Thanks for all the good info.
_______________
Thomas
'78 Silverado
'74 Monte Carlo
Old 10-09-2007, 05:39 PM   #7
BCOWANWHEELS
i do my I-6 ENGINES AT 1/2 TURN but i never hi-rpm them. 1/4 to 1/2 will be fine. got me thinkin on the 1/4 turn now !!!!!!!!
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 10-09-2007, 05:54 PM   #8
67_C-30
67_C-30's Avatar
Just because the cam and induction is not going to let the engine rev high enough to need the extra RPM capability.
My trucks
Old 10-09-2007, 06:23 PM   #9
2bits
2bits's Avatar
I am taking Friday off so I am going to get them set then and lets hope this is all it is!
_______________
Thomas
'78 Silverado
'74 Monte Carlo
