Who's using Hedman or Hedman Elite headers?
I have dynomax headers now. They have an oval port and leak against the vortec heads and nearly have to be remove just to change the shorty Accel plugs.
Considering these 69890s. I know the regular Hedmans have a bad rep and for good reason, but the Elites are coated, with 3/8 flange and 14-ga primaries. How is the spark plug access with these? ![]() ![]() http://store.summitracing.com/partde...365+4294776445 Regular hedmans have similar tube routing, just thinner.
1969 C10 Stepside, 350ci, 700R4 Last edited by CentralCoaster; 10-09-2007 at 12:11 AM. |
Re: Who's using Hedman or Hedman Elite headers?
I think they are the exact same one then my Non Coated ones. I paid $130 a year ago, I love 'em. As far as your Gaskets, Go buy your self All Graphite gaskets. I bought mine at Car Quest for $28, they don't leek and Are re-usable.
And I also can use standard size plugs.
There is no replacement for displacement! |
I don`t have plug problems from mine.I have the Elites and a set of Torq-Steps that I had coated.I`m happy with them both.
Regular Hedmans with no problems...only have one plug that is hard to get out...others are easy. I love the fit and no leaks at all.
Kelly '05 GMC Sierra SLE Z71 Bone stock except for new bed rail caps. |
If you do get them let me know how it goes these are the ones I would like to get.
1968 c10 lowered 3" 4" 355/Th400 built by Hatfield racing in joplin MO |
Maybe I must be the only one who had problems with my Hedmens. To me, they are "JUNK". Ask 70c10 about them. I bought them from Summit and then sent them off to Jet Hot. My mistake is that I didn't fit them on first. Anyway I ended up having to bet the hell out of a couple tubes, not to mention that 2 of the plugs are almost impossible to get to.
My son got the Elites, and within a year the coating starting coming off. Off course he drove his blazer back and forth to work. So, If you're not going to be putting miles on the Elites, the coating may last. I've since bought a set of Hooker Comps that are coated. Haven't put them on yet. Hope that they work.
1997 GMC Sierra Ext 1965 Mustang |
I like mine. I was impressed that all the plugs were easy to get to. I can take out every one of my plugs with a ratchet and socket. The no. 6 plug wire is a different story though. Getting the wire boot on and off is kind of a booger and you don't want to attempt it while the headers are warm.
Hedman gives a 5-year warranty on the finish on the Elite brand. It has a thermal coating, but it's not ceramic coating.
I have a radical idea!
I've always had great luck with Hedmans. I've got them on my '69 C-30 car hauler and my 82 Z28. I've been usig them for years, on lost sof different cars and trucks, and they've always fit good and sealed up well.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
#9 | |
Hedman site says: "The alloy of ceramic-metallic composition used by hedman, now known as HTC (Hi-Tech Coating), was and still is considered the very best thermal coating available for your hedders. I assume the HTC is the same stuff on the Elite headers. You can get coated base headers or coated Elite headers. Are they coated on the inside? |
They were coated inside as far as I could see. You can call Hedman direct and ask them the specifics.
They are a good company.I`m sure not perfect,though.I had my TorqueSteps coated by a business that has done my electro-static coatings for 20 years.They give me good prices but,mostly,I know I get a top quality job.I don`t run the truck much,but it has been in the rain.I don`t take it 4-wheelin`,either.I see rust started on my collector area.I just wonder how much better this stuff really is.I just had them use the black for all the coats.Maybe the silver seals better.I need to ask him.But,he never gave me the impression it mattered.Just most people want the money to show with shiney headers.
