Old 10-09-2007, 12:23 AM   #1
ofnaman
ofnaman's Avatar
Carb or tbi
I am debating on putting a new carb on my truck or switching to tbi. I have a 402 and have almost all of the stuff to convert to tbi. It will cost about the same either way I go, but I am still not sure. I have converted a few vehicles to fuel injection and have had really good luck with it, I am not sure why I am hesitating, but something keeps holding me back. What do you think? Thanks
A sweet 2000 Deville.....
ofnaman is offline   Reply With Quote
Old 10-09-2007, 03:17 AM   #2
extd56
extd56's Avatar
Re: Carb or tbi
I am putting the TBI setup in my 67 and my 69 trucks. I like the looks of it and it is some what easy to do. I also still have an extra intake and computer from a 1991 Suburban that had a 454 with TBI that I sold the motor but kept the TBI and computer.
extd56 is offline   Reply With Quote
Old 10-09-2007, 11:07 AM   #3
svgould
Active Member
svgould's Avatar
Re: Carb or tbi
I love the tbi that I put in my, will never go back to a carb.
1971 SWB SOLD
  • LT1 motor / 4l60E transmission
  • ECE front dropped spindles with stock height springs
  • 4" rear springs
  • Coys Wheels 18 x 8 all the way around
  • Hydratech hydroboost brake system
svgould is offline   Reply With Quote
Old 10-09-2007, 12:06 PM   #4
davidh
davidh's Avatar
Re: Carb or tbi
are you guys swapping in the whole tbi motor or just the throttle body part??
Even the nicest dodge-chrysler is only 2years away from being parked outside of Section 8 housing.
davidh is offline   Reply With Quote
Old 10-09-2007, 12:36 PM   #5
chevelle
instagram "footbraker67"
chevelle's Avatar
Re: Carb or tbi
it all depends on what you are going to do with it, if you are looking for performance the carb would usually be better but if you drive it everyday i would go with the TBI. I put a TBI and 700r4 combo in my 67 daily driver and i will never ever go back to a carb. just my 2 cents
chevelle is offline   Reply With Quote
Old 10-09-2007, 02:06 PM   #6
67_C-30
I have a radical idea!
67_C-30's Avatar
Re: Carb or tbi
For a driver, I'd go with TBI also...
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 10-10-2007, 05:59 PM   #7
clay68c10
clay68c10's Avatar
Re: Carb or tbi
I'm totally diggin' my TBI. Way better driveability than any carb.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 10-10-2007, 06:20 PM   #8
ProStreet68SB
The Engine Whisperer
ProStreet68SB's Avatar
Re: Carb or tbi
if you want some performance but still want a TBI. There are a couple guys on 454ss.com the modify the 454 throttle bodies, and they flow 750+ cfm. So then you can have your cake and eat it.
ProStreet68SB is offline   Reply With Quote
Old 10-10-2007, 07:02 PM   #9
67_C-30
67_C-30's Avatar
Re: Carb or tbi
You do that, or buy the Holley 670 cfm throttle body, and have the chip flashed. I put a 350 in place of a 305 TBI in '89 RS Camaro years ago. It ran really good, but the 454 throttle body is capable of more cfm if modified than the Holley 670 is. I made a phenolic spacer on a CNC mill that smoothed the transition from from the 2" butterflies on the 670 throttle to the 1.56" bores in the factory intake. The best way to go is with an aftermarket intake with the bigger bores, but mine did perform well with the spacer.
My trucks
