Old 10-09-2007, 05:34 AM   #1
loader820
sb 350
any one have pic on how to take a sb 350 apart i hve to get the heat done over
loader820 is offline   Reply With Quote
Old 10-09-2007, 05:55 PM   #2
streetstar
streetstar's Avatar
Re: sb 350
Spend $20 - $25 on a re-build manual at your local bookstore-- there are a lot of good ones , or maybe the library has one to check out
streetstar is offline   Reply With Quote
Old 10-09-2007, 06:07 PM   #3
Billla
Billla's Avatar
Re: sb 350
Look for the right books in the Overhaul Tools thread in my signature...that's the right place to start.
A factory service manual is always a good buy, as are the aftermarket (Hayes, etc.)
Billla is offline   Reply With Quote
Old 10-09-2007, 07:41 PM   #4
75shortysocal
350+dual flows= fun :)
75shortysocal's Avatar
Re: sb 350
the head? you gotta do both, and you dont have to take the whole engine apart...just the top half.
ALWAYS CHECK YOURE FRONT WHEEL BEARINGS!!
SPINNING OUT ON THE FREEWAY DUE TO THE BEARING GOING OUT IS PRETTY HAIRY!!!
75shortysocal is offline   Reply With Quote
Old 10-09-2007, 07:52 PM   #5
Ivan D.
glamoros piece o' lowlife
Ivan D.'s Avatar
Re: sb 350
pics of my 350 during tear-down:
http://www.supermotors.net/vehicles/...ry/15769/53201
The more I drink, the more I drink, the more I drink...
diesel, reg cab, long bed, 4 across the rear, single stack, wooden stakes, and lotsa lights - the Hay Express
Ivan D. is offline   Reply With Quote
Old 10-09-2007, 08:36 PM   #6
Billla
Billla's Avatar
Re: sb 350
Not to go OT - but why would you remove the crank without removing the rods first?
Old 10-09-2007, 08:45 PM   #7
Ivan D.
Ivan D.'s Avatar
Re: sb 350
cause tis easier to just lift the crank out then push pistons out - of course that crank got junked, wouldn't do it with a crank that I plan on reusing
Old 10-09-2007, 09:14 PM   #8
lurch115
lurch115's Avatar
Re: sb 350
what was wrong with the motor??? i'm guessing from the pics that it was a wrist pin??
"Horsepower is how fast you hit the wall, torque is how far you carry the wall with you."
'84 chevy half ton short box 2wd, 67,000 actual miles
'03 chevy 1500 HD crew cab 4x4 standard box, 6.0L
lurch115 is offline   Reply With Quote
Old 10-10-2007, 06:36 AM   #9
loader820
Re: sb 350
the number one rocker is lose an more rocker are lose the timing is off it is missing so i like to redo the head over
Old 10-10-2007, 08:01 AM   #10
Billla
Billla's Avatar
Re: sb 350
The rockers being loose has nothing to do with the head unless some studs have pulled out. You can check this by pulling the rockers and putting a straight edge across the top of the studs. It's possible to remove a pulled stud and install a threaded stud in the car if you're careful...not a great choice, and not something I'd do for more than one or two studs - but possible. I would definitely adjust the valves before we start thinking about pulling the heads.
If the timing is off, set the timing
If it's got a bad miss and ticking, it may be that the cam has wiped a lobe or two - again, that's not a problem with the heads.
You need to do a bit more diagnosis before making a decision on the repair.
Old 10-10-2007, 04:38 PM   #11
Ivan D.
Ivan D.'s Avatar
Re: sb 350
No problems with the wrist pins, there was very little oil pressure at start up and it when hot it was all done by 2k. Also had bad leaks at the intake, and was mixing coolant with oil (which probably wiped the bearings to begin with). A new crank, cam, and new bearings fixed it nicely, also threw in a high-volume oil pump and re-ringed it. While it was apart I also ported the heads, granted they're 882 heads so nothing to write home about, but it was a good learning experience.
