Old 10-09-2007, 01:57 PM   #1
70C10Step
70C10Step's Avatar
c20 van parts???
Bought a 86 c20 van to get the 350 and 700r4 transmission for my 70 stepside. the van is 3/4 ton. is there any other parts I can use off this van for my 1/2 ton.
All Toys:
1971 C10 Fleetside - I needed it!
1970 C10 Stepside - Midlife Crisis
1969 C20 3/4 Longbed - Beast!
1966 Mustang Fastback - Daily Fun
1965 Mustang Fastback - Money pit!
70C10Step is offline   Reply With Quote
Old 10-09-2007, 05:16 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: c20 van parts???
Side marker lights go right on, and I think that's late model enough to have the smooth ones that put out a bunch of light.
Old 10-09-2007, 06:02 PM   #3
DieselEater
DieselEater's Avatar
I'd bet a drag racing type would want that metric 14-bolt semi float rear axle.... It's about the same as the D60's used in the Hemi muscle cars. Is it eight lug or six?
A.....
69' 3/4 4X4
470ci BBC
700 HP....
D60/14bolt
205/465
http://profile.myspace.com/index.cfm...ndid=127691959
DieselEater is offline   Reply With Quote
Old 10-09-2007, 06:24 PM   #4
Longhorn Man
probably a 5 lug with normal C clips.
Old 10-09-2007, 06:57 PM   #5
sixnine
Longtime Member
sixnine's Avatar
I can't remember what year they started putting the ignition on the column in the vans - but if it has a dash mounted ignition and a tilt column you can use the column in your truck.
Rokcrln - "I'm a major car addict so trying to go as low buck as possible is like asking a coke head to use flower to save money."
1972 C10 Short Step -http://67-72chevytrucks.com/vboard/s...d.php?t=261405
sixnine is offline   Reply With Quote
Old 10-09-2007, 08:46 PM   #6
70C10Step
70C10Step's Avatar
The rear end is 5 lug and the column has the key....
All Toys:
