10-09-2007, 03:50 PM | #1 |
Pics of bagged with stock trailing arms
How low can you go before they hit the frame? Pics???? Thanks
10-09-2007, 03:57 PM | #2 |
Re: Pics of bagged with stock trailing arms
Can you get as low as these with the arms???
10-09-2007, 04:25 PM | #3 |
My guess is yes, because, My frame/cab only is sitting with no rear coil springs in it at all... the rearend hits the frame. The trailing arms don't hit anywhere...
You would probably wanna C-notch to go as low as in above pictures. And also may have pinion angle issue... I bet a member of the bagged crowd will jump in soon.
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White Last edited by 67 cst swb; 10-09-2007 at 04:26 PM. |
10-09-2007, 04:32 PM | #4 |
I have a radical idea!
The trailing arms are not hitting the frame on this '71 I have (sorry about the bad pic). It does need to have the frame notched to have adequate suspension travel though. It is low enough that it drags on anything except flat ground.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
10-09-2007, 06:39 PM | #5 |
if u look at my build thread i have a 1969 with stock style trailing arms they were build out of 2x3 rectangle tubing but were made the same as original, the truck has a huge notch but is laying frame on stock trailing arms, i know you probably dont want to cut that much but just dont think u have to 4 link a truck to get it low.
Brandon 67 chevy CST 68 chevy stepside US ARMY truck 69 chevy longbed green and white Custom10 05 Honda Rancher AT with 26 inch ITP 589's 2008 Chevy crewcab vortec max 4X4 pickup 1969 Chevrolet layin frame Project Fools Gold http://67-72chevytrucks.com/vboard/s...d.php?t=257593 |
10-09-2007, 08:04 PM | #6 |
If you wanna go lower and the trailing arms are hitting the frame, use some blocks to gain more frame to arm clearance.
10-10-2007, 02:00 AM | #7 |
A guy with a truck
Absolutely. You can do that with just a C-notch out back. But remember, those trucks are dumped. If you wanna ride at that height, you're gonna have to put in a little more work, but nothing you can't handle. I will get you a pic of my Blazer tomorrow and as low as you can go before running into trailing arm/frame interference.
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy Last edited by gringoloco; 10-10-2007 at 02:02 AM. |
10-10-2007, 08:11 AM | #8 | |
10-10-2007, 08:48 AM | #9 |
A guy with a truck
Well, my camera is dead, but I pulled some pics from Frizzle Fry's Tahoe build. This is as low as you can go with bags in the stock location on trailing arms. His notch could have been a little shorter if he weren't running the sway bar on top of the axle.
This is exactly what I am in the process of doing. I am taking an 8" step notch and cutting it down to about 6" so it will fit under the back seat. That will get you plenty low...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
10-11-2007, 02:10 PM | #10 |
Thanks for the props Chris.
That's with 3" lowering blocks and no upper spring pad above the bags: bags mounted directly to the frame and arms. I don't recommend 3" blocks unless you have at least 20" wheels. You can get away with smaller wheels (no less than 17") and 3" blocks if the shocks are relocated like mine (lower shock mount is normally the lowest point). Last edited by Frizzle Fry; 10-11-2007 at 02:10 PM. |
10-11-2007, 02:15 PM | #11 |
Thanks for the pics guys that is what I needed to see. I believe that will be plenty low enough for me. I guess the wheel tubs will still need to be moved up about 3" right?
10-11-2007, 02:51 PM | #12 |
Depends on how tall your tires will be but I'm going to replace my tubs with these (13" wide ~4.75" additional height, they won't be as high as shown in the pics). I probably only need ~3" but it'll be cleaner to bring them up to the bottom of the "rail" bellow the window which is 4.75" above stock:
10-11-2007, 05:27 PM | #13 |
Happy to be here
Stock Trailing arms, stock bed floor, modded rear inner wheelwell...
10-11-2007, 10:18 PM | #14 | |
I can not wait... Thanks for the insperation N2TRUX... P.S. And it makes me miss Texas knowing your in Texas already...
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White Last edited by 67 cst swb; 10-11-2007 at 10:18 PM. |
10-12-2007, 12:22 AM | #15 |
Epoxy Primer Friendly
Stock trailing arms.......
10-12-2007, 12:32 AM | #16 |
A guy with a truck
OK. Got the camera charged and took some pics of how low you can get with bags on the arms w/ a step notch.
This is a conservative estimate of how it will sit aired out w/ a 2" block. I've got some 3/4" billet + the ECE track bar mount that will get me 1" lower. You can see on the inner pic that you will definitely have to raise the tubs. I will use the same trailer fenders mentioned by Frizzle, cut down to fit. I measure that I will be able to cut the notch down from 8" to about 5.5-6". This will only protrude into the bed floor by about 4" which will fit nicely under the rear seat. The last pic is the plan to get the front low...
10-12-2007, 09:14 AM | #17 |
10-12-2007, 09:16 AM | #18 | |
Thanks |
10-12-2007, 10:13 AM | #19 |
Happy to be here
Don't thank me, thank Keith (n2billet), it's all his doings. Come on home when you get a chance. Despite the rumors that we have run out of space, Texas still has plenty of room....
10-12-2007, 11:14 AM | #20 |
If and when we do move back, it will be to the San Antonio area...
maybe spring 2009
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White |
10-12-2007, 11:35 AM | #21 |
"1972 C5"
Wow, that's going to look great. Any misgivings about cutting into it?
10-12-2007, 12:07 PM | #22 |
Here is mine.. I notched the frame but not above the factory top rail.. The top of the rearend just touches the bed floor.
68 C10 Shorty TPI,Bagged, and all the good stuff. Classic trucks feature June 06, On the cover of Jegs Christmas Catalog 08 67 C10 Shorty Shop truck project Bagged and Z'd under destruction and getting nowhere fast. 64 C10 Shop Truck/Daily driver, Bagged, Dropmember, SOLD!!!! Gone but not forgotten.. 54 GMC under the knife getting a S10 chassis swap and bagged. See my build thread... 07 GMC Sierra 5/7 drop, 22's and 24's Air ride on my mind.. http://67-72chevytrucks.com/vboard/s...d.php?t=339340 See pics of my trucks in my profile |
10-12-2007, 03:33 PM | #23 | |
10-12-2007, 03:40 PM | #24 |
Sweet truck!!! I DIG IT!
10-12-2007, 03:55 PM | #25 | |
A guy with a truck
None whatsoever. I c-notched it and just wasn't happy. I want my ride height to be somewhere around where it was dumped before, maybe lower Well, maybe one misgiving: I know what I'll be doing with my free time for the foreseeable future
