Junior Member
D'oh! Killed my AC compressor clutch?
A couple days ago I was fiddling around with the underdash wiring while trying to get some fog lights wired up. Well, I must have accidentally popped off the cable connected to the bottom lever of the heater control, which acts as the AC switch (I have an Old Air setup). Of course, I didn't realize this until the next time I turned the air on, at which point the compressor violently protested. It squealed like a pig and seriously bogged down the engine. While troubleshooting, I tried the AC few more times and got nuthin' but more squealing. After I finally figured out the problem, I tried the AC again and the compressor ran, but not without a little groaning and whining (and maybe some clicking). In addition, there is a noticeable (but not as pig-like) periodic squeal coming from the alternator area when the AC is OFF. So my question is twofold: 1. What does that cable do? I figured it controls the clutch solenoid, but I don't understand why the compressor would try to run without the solenoid activated. I thought that the only thing that needed to happen for the compressor to kick in was that the clutch had to engage. 2. Did I kill the clutch, the compressor or both? 3. (So I lied a little) Why does the alternator now whine? 4. (So I lied a lot) How much is this going to cost me?
Thanks in advance, -Jamie (and Frankenburb) |
![]() Join Date: Feb 2001
Re: D'oh! Killed my AC compressor clutch?
Hey...
I will help you pay for your compressor...sell me one of your Hwy 61 trucks that I don't have, I am a very compassionate person and I have your best interest in mind! ![]()
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! Last edited by 70cst; 10-09-2007 at 05:52 PM. |
Junior Member
I'll trade you my black one for your green one
Geeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee...
Let me think on this ![]() ![]()
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
Junior Member
ttt
Junior Member
Tell me what is wrong with my AC, win $10!
Whoever's answer helps the most gets $10 from me towards a year's subscription to the Board! Please note that I do not know the answer, so I won't know who the winner is until the problem is fixed. See the first post in this thread for a description of the problem. Please feel free to ask any questions that might assist in your diagnosis. If a Mod wins, I'll donate $10 towards the board. If this thread violates some Board rule that I neglected to read, I ask Mods for mercy and am not above bribery in the form of $10 donated to the board! And now the disclaimers...
No purchase necessary. Void where prohibited. Enthusiasts of non-Chevy/GMC trucks are not eligible and should buy a real truck and join the Board. Members of my household (two cats) are not eligible and are prohibited from doo-dooing and wee-weeing in and/or on said truck. My mechanic is also ineligible, since if he fixes it I'll owe him a lot more than $10... Good luck and Godspeed! D@mn the torpedos, full speed ahead! Beam me up, Scottie! Oh yeah, and tell me what's wrong with my AC... -Jamie |
It sounds as if you fried the clutch, it has 12V going to the compressor via the two prong plug. This is what engages the clutch. The clutch is dragging and it is causing the belt(s) to squeal. Clutch is a pretty cheap fix.
05 2500HD 6.0 excab 69 LWB-Gone but not forgotten! 68 Dodge Charger 383/727 69 Dodge Charger-440/4spd |
Junior Member
If the clutch were dragging, wouldn't it just turn the compressor more slowly? I'm not sure how I could have fried the clutch, since the first sign of trouble was the obnoxious squealing. But... that's the best explanation so far!
Your compressor will need a new clutch. Stick your ear on the altenator and if it is rally lound buzzing you will need a new one too. It probaly shorted when you knoked it loose
Sounds like to me that you clutch is ok and you compressor is trying to lock up if it is stalling your motor down when you turn it on.
72 CHEYENNE 10 SUPER 468/400/3.73 |
![]() Join Date: Dec 2006
If you had squealing with the engine bogging at the same time it certainly was not the clutch slipping.It was the compressor seizing up causing the drive belt to slip (and squeal).You will need a new compressor,new filter-dryer/receiver and you will have to have the system flushed,evacuated,+new oil and refrigerant.
I'm not sure I understand how you were able to switch on the AC with what you describe as the AC switch disconnected.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent. |
#12 | |
Weekend Warrior
I would also ask OLD AIR what THEY recommend for oil type and amount. Some systems have 8oz of oil in the complete system. Lots of guys think you only need a couple oz's in the compressor only - not always true.
-'07 GMC Sierra K2500HD -'66 C10 Suburban -'68/'71 K20 Service Bed Project -'69 Chevy C30 Mason Dump -'33Ford P/U 396ChevyPowered ![]() ![]() ![]() |
#13 | |
Junior Member
The cable that I knocked off goes to the blower and kind of disappears. I figure it opens or closes one of those air deflector door thingies. There must also be a switch inside the head unit that is connected to the same lever. So it was turning on the switch (I could hear it click) without the lever connected that must've done the damage?
![]() ![]() Quote:
#14 |
Junior Member
I'm not sure it was a buzzing sound, but the alternator was making noise after I reconnected the cable, even with the AC off. Do you mean that knocking the cable off the lever shorted the alternator?
Another twist - next time I tried to start the truck, I connected the negative battery cable (I had left it off for a couple days) and no juice. No cranking, no accessories. Nuthin'. Hmmmm..... |
#15 |
Your altrnator has died and is not charging if thats what happened. You might be brtter to put an new ac unit on
#16 |
Junior Member
#17 |
I might of just went bad on its own. I could of been using more power to run the ac and it fried the altenator.
#18 |
Narrow some of this stuff down, check the battery and alternator to make sure they are ok. Your clutch in the compressoris toast.
