Old 10-09-2007, 09:05 PM   #1
badriand
badriand's Avatar
Roof drip pan gakset/sealer
What are you guys using on your roof drip pan railing? RTV/Caulk ? Thanks
badriand is offline   Reply With Quote
Old 10-10-2007, 01:52 PM   #2
Fastrucken
Junior Member
Fastrucken's Avatar
Re: Roof drip pan gakset/sealer
definatly not rtv. The silicone will trap moisture. 3M make a self leveling seam sealer. Its a two part and costs approx 50.00 and only take one tube but works great.
Graham
A good friend will come bail you out of jail, but a true friend will be sitting next to you saying, "That was ****ing awesome."
Fastrucken is offline   Reply With Quote
Old 10-10-2007, 03:30 PM   #3
QWYKTRUK
I got tired of sealing it up and just took it off! Lots of work but worth it in the end!
QWYKTRUK is offline   Reply With Quote
Old 10-10-2007, 03:34 PM   #4
53lowdown
Junior Member
53lowdown's Avatar
Cool - got any pics/tips of how to go about that?
_______________________________________
62 SWB BBW (under construction)
86 Vette Convertible
53lowdown is offline   Reply With Quote
Old 10-10-2007, 04:07 PM   #5
QWYKTRUK
it's pretty involved and I believe there is a thread on this site somewhere that details the process.I did mine many years ago. It requires a lot of welding and grinding done in stages so as not to warp or stretch the metal. Cut thru to the cab with a sawzall in 3-4 inch increments. Then cut out every other one in 2 foot sections and weld it back up. After you get all the way around, fill the welds and grind until its ready for bondo .Should take very little! Thats a short version ..
John
Old 10-10-2007, 05:45 PM   #6
badriand
badriand's Avatar
QWYKTRUK that truck makes mine look like a terd! Thanks guys for the reply.
Old 10-10-2007, 09:55 PM   #7
rickf
rickf's Avatar
I had a leak on the driver's side front corner. I wire brushed is and sanded it clean then soldered it with a propane torch. Seems to be working, and I like a metal solution way better than a goop solution.
But if you have good paint on, I could see giong with a goop patch. If you're going with goop, make it 3-M 5200 (a polyurethane adhesive/sealant).
rickf is offline   Reply With Quote
Old 10-10-2007, 11:24 PM   #8
badriand
badriand's Avatar
thanks, i fixed my rust spots but that top basically looks like it is some sort of pressed in or something. There is that little lip between the rail and the roof i just want to make sure no water get in under that.
