Old 10-09-2007, 09:07 PM   #1
redrat
gearhead
redrat's Avatar
what headers to use for BBC ?
i need as many opinoins on this as possible. I put a big block (454) in my 82 1/2 ton 2wd and i need a different set of header that dont rub on the frame. But I want to have good ground clearance in the front. I am running a 5 - 7 drop and dont want any problems with draging on the ground or speed bumps. Please help me find the right headers im running short on time with this project.
Thanks for all your help, Ryan
2003 GMC Z71 Daily driver
1982 Chevy 2wd short bed, project,
boxerdra@hotmail.com
redrat is offline   Reply With Quote
Old 10-09-2007, 09:15 PM   #2
AirMale
AirMale's Avatar
Re: what headers to use for BBC ?
Hooker #2455 work well
86 SWB 9.0 LITER
T-400-OD 4.11 eaton-4/5 drop
Best 1/4 12.51 @112mph no traction
AirMale is offline   Reply With Quote
Old 10-10-2007, 10:53 AM   #3
redrat
gearhead
redrat's Avatar
Thanks AirMale. Do you have good ground clearance on the bottom? i dont want the bottom of the colectors any lower than the bottom of the frame. Do you have a picture of your truck from the bottom?
Old 10-10-2007, 11:04 AM   #4
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
I am using Sanderson BB3 headers for a Chevelle.
Pics are in this post:
http://67-72chevytrucks.com/vboard/s...d.php?t=185391
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 10-10-2007, 03:43 PM   #5
AirMale
AirMale's Avatar
no pics but they tuck up inside the frame rail. Good luck and FYI these are available in stainless too!
86 SWB 9.0 LITER
Old 10-10-2007, 04:34 PM   #6
454HO
Uh, yes you do have pics.
Check out this thread -
http://67-72chevytrucks.com/vboard/s...d.php?t=256433
I have Hedman Elites. There a few pics in the link in my sig. Sorry, none from underneath.
- Greg
454HO is offline   Reply With Quote
Old 10-10-2007, 06:37 PM   #7
redrat
gearhead
redrat's Avatar
What part number for the Hedman Elites ??? And do they have good clearence? (no lower than the bottom of the frame)
Old 10-13-2007, 11:03 AM   #8
454HO
I believe I have part number 69820. But check the footnotes on the Hedman site to confirm that's right for your application.
http://www.hedman.com/pages/hedmanmain.html
Ground clearance looked okay when I had them on the '77 long bed, but I never got to actually drive the truck. I can't say they didn't drop below the frame... I think they would have to to get under the transmission crossmember. The headers will be going onto the '86 short bed as soon as I get the engine swapped in. I will make sure to get some pics then.
- Greg
