10-09-2007, 10:39 PM | #1 |
65 - Chevy C10
Lucas Oil stuff
Just curious if anybody uses this. Im tempted to get some after my break in oil change. Is it just a gimmic?
10-09-2007, 11:22 PM | #2 |
Re: Lucas Oil stuff
i constantly use lucas oil treatment in my 72 and my 92 chevy. i also used in cat engine when i was a owner/operator. it boost the oil pressure a little and it also helps on cold start ups.
Freedom is never more than one generation away from extinction. We didn't pass it to our children in the bloodstream. It must be fought for, protected, and handed on for them to do the same.... Ronald Reagan |
10-09-2007, 11:50 PM | #3 |
65 - Chevy C10
Re: Lucas Oil stuff
Cool... anybody else?
Do you fill up oil as normal and then add that? A whole bottle? |
10-10-2007, 01:39 AM | #4 |
Re: Lucas Oil stuff
Never overfill the crankcase.
10-10-2007, 01:48 AM | #5 |
Between the earth and the sky
Re: Lucas Oil stuff
I always add a quart of Lucas, to everything except my BMW (which uses synthetic) I do one less quart of oil and replace it with Lucas.
Chris - 1966 C10 Shortbed Fleetside, 1991 GMC Sierra 1500 Extended Cab, 1993 Blazer Sport 4x4 My other rides: 1969 Chevrolet Impala SS427 Convertible 1976 Dodge Tradesman B200 2002 Nissan Maxima 6 speed 2004 Mercedes Benz CL500 |
10-10-2007, 11:57 AM | #6 |
Re: Lucas Oil stuff
i wouldnt use it on a new engine. lucas actually thickens the oil like molasses and makes a slick film on everything and that film collects crap and doesnt allow your oil to clean like it should.
10-10-2007, 12:20 PM | #7 |
Re: Lucas Oil stuff
well i used it cuz i was haveing a prob whit low oil presser and i put some in my motor and it started nockin ofter that but i got good oil presser now
ridin big yo 5in cpp lowerin springs in back lowered 3in in front with cut springs for now 5 lug swap and disk in front 5 lug and disk in the rear with 3.23 gears mild 350/400heads 7547weiand intake 600 Edelbrock chrome block hugger headers 2 1/2 pipes in to a x pipes super 40 flows and turn downs turbo 350 with shift kit |
10-10-2007, 12:25 PM | #8 |
Re: Lucas Oil stuff
im not saying it doesnt help but i wouldnt use it on a new engine like first post asked
10-11-2007, 06:28 AM | #9 |
Rust Buster
Re: Lucas Oil stuff
In this area, the parts houses can't hardly keep it in. I have to order in extra between trucks because I run out continually. Great product. Big City, they have a Synthetic version out for Syn oil users. - Jerry
10-11-2007, 08:08 AM | #10 |
Re: Lucas Oil stuff
Thanks for the info man, I did not know that!
10-11-2007, 10:02 AM | #11 |
65 - Chevy C10
Re: Lucas Oil stuff
So do you recommend I use it on my newly rebuilt engine?
10-11-2007, 10:04 PM | #12 |
Rust Buster
Re: Lucas Oil stuff
Sal-give it a break in period.....I have always suggested 5000-6000 miles for a proper break-in to all my customers before adding any additives to oil. See if others agree. Even when I run synthetic, I break in with regular oil, 1000 miles first change, 3000 second change, then I go to synthetic at 5000 miles. I had 260,000 miles on a 91 suburban bought new before a hail storm totaled the truck, and 130,000 currently on my 99 s10 bought with 12,000 miles and immediately switched to synthetic the day after I bought it. Not an engine problem(oil related) with either. My 65 c30 when done will be syn as well. Jerry
10-11-2007, 11:40 PM | #13 |
65 - Chevy C10
Re: Lucas Oil stuff
Right now Im running straight 30wt oil with no detergents. When should I switch to something else? and what wt. should I start using after this?
10-12-2007, 03:19 AM | #14 |
Re: Lucas Oil stuff
after the second oil change i say. you have to actually have friction for everything to seat.
10-12-2007, 11:19 PM | #15 |
Rust Buster
Re: Lucas Oil stuff
10w40 or 15w50 either one is great for a V8 and the viscosity does not change with temperature, so cold weather startups are NOT a concern.
10-12-2007, 11:43 PM | #16 |
65 - Chevy C10
Re: Lucas Oil stuff
when should I get rid of my straight 30 wt?
