ut oh...notch question!
I am going to be notching my rear on my 55 chevy truck. I forgot to mark where the rear and frame come into contact.
Does anybody know where the frame and rear come into contact so that I do not have to put the rear back on the leafs and mount them to see where they hit? I have the stock bump stocks taken out and can use the center hole of the bump stock as a reference point if need be.
Lotus Current Rides/Projects 1955.5 Chevy shortbed truck 1952 Chevy Coupe Deluxe car |
Re: ut oh...notch question!
Thats were you want to go by. The bump stops are the center point.
Classic Trucks Link http://www.classictrucks.com/feature...uck/index.html 1958 GMC.Project Build http://67-72chevytrucks.com/vboard/s...d.php?t=162816 1966 Chevelle Build http://67-72chevytrucks.com/vboard/s...d.php?t=443576 Video http://www.youtube.com/watch?v=prrNKo8F7Zw#GU5U2spHI_4 |
Yellow truck club
![]() ![]() That's what I used Brian ... ![]()
................................................................ Brian ...... ![]() My hub garage address http://www.hubgarage.com/mygarage/59apache I gue$$ everything has it'$ price ALL GONE NOW ![]() ![]() ![]() ![]() PRAISE THE LOWERED 350 700r lokar shifter power MII front end, shockwaves tilt, 4 wheel discs 4-link and bags 10 bolt limited |
![]() Join Date: Mar 2005
Make sure you support BOTH sides of the frame (fwd and aft of the notch) during the whole process. Make initial measurements to the ground (make sure they're even from side to side) and write them down. That way, if anything ever happens during the install, you have them as a guide.
I always try to keep the original frame uncut until the last possible moment. If you're installing a c-notch, weld it in first then backcut the remaining metal. Use the same principle if you're doing a step-notch as well. I've seen more than a few trucks where the frame sagged down in the rear during the notch job, and it leaves a tapered gap where the bed meets the back of the cab. You can shim it up to match, but then the rear bumpers look out of place. |
I took the shackles off to relieve the weight/pressure that they apply.
I have jack stands right before where the notch will be. I have jack stands right after where the notch will be. I plan on boxing that portion of the frame first then cutting out for the notch and then welding in the c notch. I do not plan on going more then half way up the frame with the notch.
Certified Car Nut
Yeah I used the center of the bump stop also and made my own notch and boxing plates.
![]() ![]() ![]() Last edited by Kabwe; 10-15-2007 at 01:11 PM. |
#7 | |
http://67-72chevytrucks.com/vboard/s...d.php?t=212604 Last edited by GATORBUILT '59; 10-11-2007 at 08:18 PM. |
Certified Car Nut
I used 3/16 its about the same thinkness ass the frame. Here is a pic of the frame now. Man I can't wait to put this thing back together.
![]() Last edited by Kabwe; 10-13-2007 at 03:36 PM. |
Yellow truck club
Yea then the kids can get their blue chair back
![]() Brian ... ![]()
Certified Car Nut
Yeah thats right its a nice jack stand.lol
Man, I can't wait to see it done too! Next summer maybe for brothers show? Hope so, since I will be there for sure next year.
#13 |
Certified Car Nut
If I get this thing finished by the next brothers show I would be amazed. Well maybe if I stop changing everything I could get her done.lol By the way CAL your truck looks great.
#14 |
I am hoping to have mine driveable by the march meets...
I said that with my car when I first got it too and it took FIVE years till I drove it to the march meets. Well...off to sand some more on the inside of the cab.
