10-10-2007, 02:17 AM | #1 |
I've got grease on my mind.
GMC Parts and stuff ...new prices
Here are a few parts I am clearing out;
Lower plenum- I pulled this out of my 1967, it is very solid and does not have any pinholes that I could see. - $10 Inner Plenum - it does have some rust on the inside but is very solid and does not have any pinholes that I could see. Still has rubber cable grommet included. - $10 Shifter out of a New Process 4 speed 435 toploader transmission. Two-part design. Shift pin at bottom is loose, would need a new roll pin installed or welded - $10 Non A/c Heater Fan Motor - works - $15 Last edited by Hard Luck; 10-15-2007 at 02:47 PM. |
01-21-2008, 03:40 PM | #2 |
turn signal assem
complete NEW GM turn signal assembly -$45 + shipping
01-22-2008, 07:05 AM | #3 |
Re: 67 GMC Heater Parts and others
Any questions?
01-22-2008, 11:15 AM | #4 |
turn signal is for a box van or a big truck. The mounting studs for a pickup go straight down from the bottom of the housing.
