Headman header fit issue
I bought headman elite ceramic headers #69648 and frame on pass side stops install need pic's of frame mod. to correct this problem
My Project Old Glory trike visit here http://www.facebook.com/home.php?#!/...48577705162172 |
Re: Headman header fit issue
I have heard many people say they have to notch the frame on the passenger side. I was hoping to get those also but now I am not sure.
1968 c10 lowered 3" 4" 355/Th400 built by Hatfield racing in joplin MO |
I will NEVER use Hedmen again.....I hate the top cross over tubes and I had to dent in a few tubes to clear the frame on the right side and left lower control arm. I'm just not a fan of notching any part of the frame. Especially near the front suspension. jmho
1997 GMC Sierra Ext 1965 Mustang |
Never had to notch anything on mine,running Hedman Elites
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
Member
![]() Join Date: Jan 2007
I know alot of people like hedman. I have never had any luck using there products. They look great when you take them out of the box, but when they don't fit what good does it do. I only use hooker now, and I don't have problems anymore.
Korey 1955 Bel Air 2 door hardtop 1971 Blazer 4x4 1973 Z-28 Prostreet |
Was your truck originallly a 6-banger? If so, the top side of the frame rail is wider than the V8 truck frames. I was gonna have to notch a huge section to get those on mine, so I sent them back and got the long tubes. I only had to notch a couple places in the frame for them to fit.
DOH My bad yes it was a 6 banger sorry.still would purchase them again u only need to trim a tad out like an 1/8" if that.Oh well do what u like and be happy
Pictures men - we need pictures!!!
Chuck 1972 C-20 Longhorn 402 BB .030" over (409?), curved HEI, RV cam, quadrajet, dual 3" exhaust, TH 400 ported w/shift kit 1999 K1500 Suburban (old style) 5.7L Vortec 4L60E "No matter where you go, ........ there you are" |
This is why......the picture of the spark plug wire being burned, was before I put these looms on.
F.A.S.T. president
![]() Join Date: Sep 2003
I dont remember what part number these are but I had to notch both sides.
F.A.S.T. President and Founder Fabricators for the Advancement of Sawsall Technology "A fear of the Sawsall is a sign of retarded sexual and emotional maturity." ~Sigmund Freud, "General Introduction to Psychoanalysis" |
I can't understand why you can look at other header makers, and they don't have the crossover tubes going in front of the spark plugs like Hedmen and even hooker comps. But they put that tube right in the way. WHY??
It's not like they are tuned headers, and need to make up length. Just my rant......
Jamis : do you have pic of pass side my driver side worked fine Hedman says there are no issues
My Project Old Glory trike visit here http://www.facebook.com/home.php?#!/...48577705162172 Last edited by ibad57; 10-12-2007 at 07:10 PM. |
#13 |
F.A.S.T. president
They told me the same thing....I told them they were right I just didn’t have a big enough hammer to make them fit without notching my frame.
I didn’t return them because I like the collector design. The drivers side collector is way too close too the bottom of the frame wall as well. Its a shame they dont fit better. ![]()
F.A.S.T. President and Founder Fabricators for the Advancement of Sawsall Technology "A fear of the Sawsall is a sign of retarded sexual and emotional maturity." ~Sigmund Freud, "General Introduction to Psychoanalysis" Last edited by jamis; 10-12-2007 at 09:42 PM. |
#14 | |
F.A.S.T. president
I actually prefer them that why because I don’t like to run my wires on top. With the tubes on top you can drop your wire under and behind the engine. Makes it a lot cleaner IMHO. But must guys seem to like running the wires on top and over the valve covers or use the nice looms like you have. I actually had to run them on top anyway because I ordered the wrong set of wires. But I will later get the un-cut set and run them underneath the way I like.
F.A.S.T. President and Founder Fabricators for the Advancement of Sawsall Technology "A fear of the Sawsall is a sign of retarded sexual and emotional maturity." ~Sigmund Freud, "General Introduction to Psychoanalysis" Last edited by jamis; 10-12-2007 at 09:36 PM. |
#15 | |
blood type; Retumbo
my 68 was originally a 6 banger and I had Hedman's which fit with no mods at all. of course they were the low priced full length ones. nothing fancy for my POS. ![]() |
#16 |
So in the first two pictures above thsi post, am I to understand that the fram has been shaved to allow adequate clearance for the collector?
I'm trying to understand all this because headers might be on the list for a winter project and i want to know what- all in im for. IMO, it seems like the header pipes should maintain a flatter profile while passing by the frame rail, then go together into the collector once below it. Does anyone know if it is a big problem to solve this with a 402 BB?
#17 |
In those pics, I had to flatten the tubes to clear the frame and left side lower control arm.
#18 |
Grand PooBaa Member
When I installed my Headman headers, the plain black one, I had to install one side from the bottom. Cant remember which. One side just dropped right in from the top, the other I had to work it through from the bottom.
Did not notch anything. |
#19 | |
F.A.S.T. president
I cant comment on the 402 fit its a diffrent animal. I do remember TxFireFighter having issues with BBC headers many moons ago.
#20 |
A few of the people coment there's fit fine needed both sides notched Keep in mind we are refering to the fit in a 1972 chevy truck that does have a narrower frame and the Headman header is the short ver.
part number 500 69890 that is the elite with ball collector. now the only problem I found to this point is top of pass side frame needed a trim as the following pics will show The only other issue is possably heat off this header near the fuel line that runn allong the frame.
