I have a 1971 C10 stepside I am looking at putting a 1973 Olds 350 and auto transmission in and was wondering if anyone had done this one before and could offer any advice.
I did try searching but couldn't really find anything. Now, I understand this combo is not ideal but it is dirt cheap and can get me going down the road for now while I work on brakes, chassis, wiring, etc. Because the stock 250 and crappy tranny now won't do it. Then I can build the small block I want. Thanks for any help. Erik. |
Chevy nut
Re: Engine Swap
You have to move the mounts. The olds mounts sit farther back then a Chevy does. i have put Olds motors in everything. I even stuck one in Dodge ram 92. make sure you have the Olds frame mounts. The Chevy mounts wont work. The cross member for the trans should be ok.
84 Chevy Custom Deluxe 1/2 Ton Named Fade To Black II "Remember kids there is NO replacement for displacement!" |
Re: Engine Swap
I assume it is a 3 speed or 4 speed manual behind the 250.
Whats wrong with the 250, - does it not run? If it runs at all - its already better than an Olds 350 for your truck, and a new clutch, if the tranny needs it would be less than the cost of modifying your driveshaft for a weird engine swap. Tons of people swap in Olds and Buick engines - but usually the 455's |
Re: Engine Swap
Thanks for the help
![]() Join Date: Jan 2001
Re: Engine Swap
I think you'll love the rocket motor. Olds motors are pretty much indestructible. Have fun with it.
its all about the +6 inches
Re: Engine Swap
I'd take an olds over a 250 too personally. Probably no need to mod the driveshaft either. Install the correct yolk for the tranny you'll use, slap the tranny in there supported by a good jack, slide the engine in, if it clears everything, drill the holes, mount the engine, and call it good.
My Longhorn had a pontiac 350 in it when I got it, I pulled it out and tossed a caddy engine in it. If I had to do it all over again, I woulda done it the exact same way. |
