Kung Fu Master
![]() Join Date: Oct 2005
Steering column shaft question?
My steering wheel has play a little in and out so I decide to investigate the problem. Well, it looks like there is some sort of bearing on the end of the column where it comes out of the firewall and it has come loose? How does this fit on the end? Is it pressed in, or is there some other mechanism holding the shaft in place? It seems as though there should be a clip on the steering wheel side maybe. As it is, with the steering wheel off, I think I could just pull this shaft right out the bottom end. Any suggestions? How can I get this corrected? Thanks
72 GMC SuperCustom 4x4 1972 Chevrolet Cheyenne Super 4x4 |
It's a catastrophic success.
![]() Join Date: Jan 2003
Re: Steering column shaft question?
Looks like you may be missing a keeper clip.Heres a tilt but the bottoms ought to be the same
Project Junkie! Fishing Poor!!
![]() Join Date: Dec 1999
There isn't a keeper there. What is missing is the big flat washer and spring. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
Kung Fu Master
I did take the big flat washer and spring off for the pic. Would the spring lose tension? With everything back together, it just wont quite stay tight?
Kung Fu Master
Would a new spring help with this? Or...
sorry to bring up a old post but i have a similar problem.i got the spring and big washer on,but even with the steering wheel on tight i still have a little up and down play.and it does'nt look like the clamp at the end of the shaft will go up to put tension on the spring.i already put new bearings on it.so is there a way to get the clamp to move up or do i have to use more washers,because when i took it apart before it only had 1 big washer.thanks
1970 c-10 2wd longbed |
#7 | |
TILT COLUMN GURU
![]() Join Date: Dec 2006
kevs_classics64 64 Impala SS Conv 72 Blazer 2wd 75 Jimmy 2wd 63 Belair wagon 02 Silverado ext cab. DD RIP EL JAY |
sorry been working on other things for the truck.yes replaced everything in column.plastic turn signal with wiring,upper and lower bearings.column was clean when taken apart.its not much up and down play.not as much as the guy earlier in the post.maybe 1/6 1/32 play.rag joint is new.i have schematics so it went back together right.
70 Chevrolet=Obsession
I don't know about three-on-the-trees or automatics but on mine just below the spring and flatwasher is a big cast iron clamp. When the steering column is all together you gotta push the big clamp up the steering shaft until it just begins to compress the spring and then tighten the clamp.
![]() ![]() ![]() I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke! IT'S NOT EASY BEING GREEN! -Kermit the frog 1970 Chevrolet C-10 Longbed Stepside : 350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes) 1996 Toyota Corolla (Parts runner) |
Here's a pic of a non-tilt column.
![]() ![]() ![]() LIFE AIN'T EASY WHEN YER FAT AND GREASY! GMC= Got More Class! ![]() ![]() |
