Torque Specs, Front crossmember???
Does anyone have the torque specs for the lower 6 bolts (3 a side) that connect the front crossmember to the frame. Also need the torque specs for the 8 bolts (4 a side) that connect the front crossmember on the side of the frame.
Thanks in advance!!! Alex
Alex 1971 Lil' Red 350 SBC 700R4 Last edited by ChevyDude; 10-10-2007 at 02:23 PM. |
![]() Join Date: Oct 2005
Re: Torque Specs, Front crossmember???
I just made mine really really tight!!!
BTW.....frame looks very nice.....is that for your new project or is that a pic from the Red truck?
72 Cheyenne SWB Fleet Nut & bolt frame off in progress...99.9999% - supercharged 383 - 4 wheel discs - relocated fuel tank - ![]() My Build Thread Last edited by SactoJim; 10-10-2007 at 03:31 PM. |
Thanks Jim. This is the frame from my 68'...Project OverKill.
Alex 1971 Lil' Red 350 SBC 700R4 |
Don't know....you should have put in an extra "really" on the tighting.....
1997 GMC Sierra Ext 1965 Mustang |
![]() Join Date: Dec 2006
![]() Hope this comes out OK> 65 for C-10 and 100 for C-20/30
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme. |
One grunt...not two. I used the same chart as above and it tightned down nicely. Make sure you use grade 8's! I was going to use stainless till I started thinking about how it would all go horribly wrong if that fell off whilst driving.
Will this thing ever get done!! ![]() |
#7 | |
so easy a caveman can do it...
![]() Join Date: May 2006
...just had to quote you so that pic was in the thread twice! That looks great! I don't want to do that with mine, but I'll probably end up doing it anyway! ![]() Well, it didn't work...oh well Last edited by Sequoyah; 10-10-2007 at 10:07 PM. |
Thank you WorkinLonghorn.....and here ya go Sequoyah, the project is named OverKill....so not much being over looked. Grade 8 for sure.
Alex 1971 Lil' Red 350 SBC 700R4 Last edited by ChevyDude; 10-11-2007 at 12:29 AM. |
I have to agree with the "toss in an extra really" comment, this isn't something where the the torque specs matter however, I know it's probably a long shot on it happening, but looking at the photo of the frame, I'd run the bolts with the nuts on the bottom. If by chance all six nuts loosened up, the bolts would fall right out and there goes the front. If the bolts were reversed, it would be loose but wouldn't come out from under the truck. But, it's probably not something that would ever happen.
67 Short Step, 355, 700R 4.11 posi rear, 4/6 drop Discs on all 4 corners. Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=219094 Last edited by whatnow123; 10-11-2007 at 12:43 AM. |
Bolts ain't comin' loose once I torque them down, and they came this way from the factory.
And in that case.....maybe I should turn the U bolts over that hold the lower control arm on ...so when the nuts fall off, yeah right....LOL!!!
Alex 1971 Lil' Red 350 SBC 700R4 Last edited by ChevyDude; 10-11-2007 at 03:09 AM. |
