Old 10-10-2007, 05:33 PM   #1
gmc67swb
gmc67swb's Avatar
bad wheel hopping
ok boys need a little help on this one....truck is a swb 67 gmc with leaf springs....7 leafs to each side so its stiff...The problem is it wheel hops,was wondering if i removed a couple of the leafs and softened it up if it would help.Have around 450hp and about 450 torque...rearend is a dana 44 with a posi.and traction bars...tremec tranny 5 speed...I know that a coil over is much better for this but was trying to get around doing the swap...any input would be great....thanks
GM 330HP/350, Magnuson 122HH, Tremec TKO 5spd
gmc67swb is offline   Reply With Quote
Old 10-10-2007, 06:43 PM   #2
71tahoe
71tahoe's Avatar
Re: bad wheel hopping
I'm no expert but I don't think taking leaves out will help. You only have one leaf that connects to the shackle and a maybe a couple more banded to it. Axle wrap is probably the culprit. Traction bars may be the only option depending on your ground clearance.
http://www.suspensionconnection.com/...raction%20Bars
71tahoe is offline   Reply With Quote
Old 10-10-2007, 09:29 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
coil overs wouldn't do jack... unless you ment a coil spring rear suspention?
Traction bars, slapper bars, lift bars, ladder bars...
how much money you have to spend? How bad to you need to stop the wheel hop?
Old 10-10-2007, 10:00 PM   #4
a1953mdl
Rusty but Trusty
a1953mdl's Avatar
You have traction bars, are they adjusted properly? Iirc you only want about 1/2" between the snubber and the leaf. Are the bars long enough to reach to the main leaf?
Alternative to changing to the coils, move the axle forward (redrill the spring perch) about a inch. That makes the front side shorter and stiffer and allow the back part of the spring to work (like old super stock springs). IMHO don't remove any leaves to reduce wheel hop.
Does it have the problem on both asphalt and concrete?
Might check to make sure every thing is tight on you rear end mounting points.
Just rattling on.... hope something helps.
Lee
72 SWB, 454 / th400... hoping the kids don't get all the parts before it gets built
a1953mdl is offline   Reply With Quote
Old 10-10-2007, 10:53 PM   #5
wibilly
wibilly's Avatar
my shortened k 20 hops real bad too. i guess i should be fixen it instead of sitten here
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 10-10-2007, 10:58 PM   #6
Bob 68327
72 Chevelle Club
Bob 68327's Avatar
On my old drag car I removed the spring retainer clip on the side behind the wheel and added them to the front side it helped the chassis load by letting the rear of the springs spread open . I have a leaf spring rear in mine but suffer no wheel hop!! Hope this helps. By the way do you know what spline the axels are in the 44 my rear is a 44 also. I need a posi. but don't know what spline the axels are !! Any help would be appreciated!!!
I Have The Right To Remain Silent,But Lack The Ability
1972 Chevelle ... Mine
2006 Trailblazer... Hers
2002 Buick century ... Kids
2002 K1500 Z-71 EXT CAB ... Daily Driver
2005 Rockwood Roo ... For Camping
1974 Harley-Davidson XLH Sportster 84'' stroker
Bob 68327 is offline   Reply With Quote
Old 10-10-2007, 11:02 PM   #7
Boog
laying low
Boog's Avatar
You may very well need to put some stiff shocks on it to help control the hop.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 10-11-2007, 06:42 AM   #8
gmc67swb
gmc67swb's Avatar
There 28 spline...
Old 10-11-2007, 06:51 AM   #9
gmc67swb
gmc67swb's Avatar
thanks for the input guys all is food for thought and longhorn thats what i meant change to a coil spring suspension...
Old 10-11-2007, 06:58 AM   #10
gmc67swb
gmc67swb's Avatar
Lee
sorry about that should have made it clearer....on street tires it will burn the tires off no wheel hop....(asphalt r concrete) its when i'm at the track with the M/T Sticky's on....
Old 10-11-2007, 05:16 PM   #11
JAKES 68GMC
Aluminum slot wheels rule...
I've got bad wheelhop problems, too. Thats probably a good thing though.
JAKES 68GMC is offline   Reply With Quote
Old 10-12-2007, 07:40 PM   #12
gmc67swb
gmc67swb's Avatar
http://www.4x4wire.com/jeep/tech/susp/axlewrap/
<-------your son
Old 10-12-2007, 07:50 PM   #13
s1lv3r
I see that they only list back to '73. Do they have any that'll fit the '67 gmc?
s1lv3r is offline   Reply With Quote
Old 10-13-2007, 03:51 PM   #14
scatesracing
Machinist
scatesracing's Avatar
I helped a freind a while back... we took out the over load spring (the 3/4 in thick short spring on the bottom) and let the tires down.... get it to grab and stay hooked... the back lowered about an inch when we took out the spring....and road better to... it helped a ton... then he put an oooold set of slapper bars on it and then it was great just my $.02
scatesracing is offline   Reply With Quote
Old 10-15-2007, 11:07 AM   #15
Scott68-93-97
Scott68-93-97's Avatar
something else you can do is extend your perches to contact more spring this will help a bit we do it on off road stuff a lot, or cut down an extra overload sping thats about 3 inches longer than the perch on each side and put that inbetween your perch and springs we did this on my yota and it almost completely stopped the wrap and hop even with 5.29 gears and dual tranfer cases
1968 Short Fleet 350/700r4
http://67-72chevytrucks.com/vboard/s...d.php?t=249435
1997 Bagged XtdCab Vortec350/4L60e
http://67-72chevytrucks.com/vboard/s...44#post2286144
1993 XtdCab Longbed 4x4 6.5Turbo/NV4500 "Daily Driver"
1985 Toyota XtdCab 4x4 22re/W-56/Dual T-cases, Doug Thorley Header, Homebrew front and rear spring packs, Tons of Mods to suspension and drivetrain, 35" boggers, coming soon ARB's and 5.29's, Possible 4.3/700r4 swap
Scott68-93-97 is offline   Reply With Quote
