![]() Join Date: Aug 2005
Notch Usage Pics for Gringo
Here you go.
For everyone else here's the specs: Full 8" KP notch with bags in the stock location, relocated shocks and 3" blocks. I can't measure it now but I think I have 1.5-2" left in the notch when aired in this config. I kept the full 8" for clearance on my camaro sway bar and future options ![]() If I wanted to lose the sway bar (or run a different style) I could have cut it down 1.5-2". |
Re: Notch Usage Pics for Gringo
more
![]() Join Date: Aug 2003
the more i see pics of your "burb" the more i am in awe of it.
A guy with a truck
Awesome man. Thanks a lot! You're just stokin' the fire...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
A guy with a truck
Couple questions on those shock brackets:
How low do they hang below the axle? Are they completely vertical? i.e. if you went lower could you lean them in at the top for more travel? Seems like if you were buried in that notch, the compressed shock would have to be like 6" tall- shortest I can find are around 9".
This is what I used from SD:
[IMG]http://www.*****************/images/products/Under_Axle_Sideways_Shock_Mounts_(Pair).jpg[/IMG] and upper is just the stud: [IMG]http://www.*****************/images/products/Shock_Stud_Threaded.jpg[/IMG] So they hang a couple inches below the axle. Yes the shocks are vertical. Maybe not the best design for max travel. They do not bottom out before the bags, but they do limit my lift. I'd like to get more lift somehow but longer extended=longer compressed so then I'd limit my drop. I may need to move the upper mounts in and go with a longer shock. |
A guy with a truck
Yeah, I actually ordered those same ones last week and then canceled the order 'cause I didn't think they would work for me. I'll do some measuring once I get the notch in...
any info on the shock location/mounts?? Also who is SD?? Thanks! My notch should be here this week and I am trying to get it all figured out..
68 C10 Shorty TPI,Bagged, and all the good stuff. Classic trucks feature June 06, On the cover of Jegs Christmas Catalog 08 67 C10 Shorty Shop truck project Bagged and Z'd under destruction and getting nowhere fast. 64 C10 Shop Truck/Daily driver, Bagged, Dropmember, SOLD!!!! Gone but not forgotten.. 54 GMC under the knife getting a S10 chassis swap and bagged. See my build thread... 07 GMC Sierra 5/7 drop, 22's and 24's Air ride on my mind.. http://67-72chevytrucks.com/vboard/s...d.php?t=339340 See pics of my trucks in my profile |
What info do you want? I was referring to ***************** (SD)
Mike did you really think we would not notice that you used innershield wire
![]() ![]() Every time I see that T-HO my mind starts wondering! Kevin LFD Inc. |
Hollister, CA.
![]() Join Date: Sep 2006
I ran 8" travel shocks to match the bags.
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster ![]() Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
#12 | |
The Site... http://www.*****************/index.php Their rear shock rolocating... http://www.*****************/ShockRel...ckMounting.php ![]() Last edited by Mkcustums; 12-02-2007 at 06:43 PM. |
#13 |
#14 |
Señor Member
Go with an axle mount with this kind of effect, and hang the shock off the back of the rearend.
![]() Go with Monroe 555003-- 9.63 compressed 14.75 extended 5.13 travel Angle them forward to the front bridge bar and kick them back off the rearend such that they are leaned 7.5" compressed (horizontal distance from eye to eye), and that'll give you 6" vertical distance from eye to eye. That is... ![]() a = 6 b= 7.5 c= 9.63
#15 |
Here's an image of the rear shock relocator kit that we sell. It's designed to drop the lower mount down and back off the axle tube, that way you'll still be able to get a decent shock selection. Plus the lower mounts can be positioned at any angle on the axle tube to help angle/offset/locate the shock to a custom configuration.
![]() http://www.kplinks.com/product.php?p...3&cat=9&page=1
#16 |
Great install pics Fry and excellent tech information on the depth of the notch with your air suspension configuration.
#17 |
Señor Member
Even if you hang it where the rear axle centerline and bottom shock mount are parallel, the distance you get to lean the shock is significant, and really adds up on the amount of travel needed to cover aired up/down heights.
#18 |
Yellow truck club
[QUOTE=XXL;2469278]Go with an axle mount with this kind of effect, and hang the shock off the back of the rearend.
![]() Go with Monroe 555003-- 9.63 compressed 14.75 extended 5.13 travel Angle them forward to the front bridge bar and kick them back off the rearend such that they are leaned 7.5" compressed (horizontal distance from eye to eye), and that'll give you 6" vertical distance from eye to eye. That is... Those are the same dimension as the 5850 shock from a 63-82 vette rear. Brian .. ![]()
................................................................ Brian ...... ![]() My hub garage address http://www.hubgarage.com/mygarage/59apache I gue$$ everything has it'$ price ALL GONE NOW ![]() ![]() ![]() ![]() PRAISE THE LOWERED 350 700r lokar shifter power MII front end, shockwaves tilt, 4 wheel discs 4-link and bags 10 bolt limited |
#19 | |
The main reason I went with the lower mounts I did was because I wanted the shock pivots to be perpendicular to the axle for better axle articulation without shock binding. Granted it's not a rock-crawler
![]() Quote:
