10-03-2002, 07:46 PM | #1 |
Oily plugs
Hey guys:
My truck started running rough when I was getting off the freeway this morning. When I got it home I pulled a couple of the plugs and they looked alright except for being covered in oil. The oil was all the way up the threads. I do not see how oil could get on the threads of the plugs. My question is: is there any way to find out where the oil is coming from? The only idea I had was to run a leakdown test and try to listen for air leaks. Also how hard is it to replace the regular o-ring type valvestem seals with the positive seal umbrella type? Thanks guys!
James Strickland AS Computer Information Systems “Ignorance is a powerful tool if applied at the right time, even usually surpassing knowledge” ~E.J. Potter |
10-03-2002, 10:49 PM | #2 |
Cantankerous Geezer
To put in the umbrella seals you need to machine a spotface on the head. Best done by a machine shop. Don't know if anyone will do it with the head on the engine. I've never asked.
Did you check all of the plugs, or just two? I would guess that oil on the threads was from an external leak, valve cover. Oil on the plug tip indicates an internal leak, either stem seals or rings. A compression check will tell you if it's rings. A leakdown check will tell if you have a valve leaking, you might be able to listen for a stem seal leak with a good ear and a tube. I was trying to think of something that would foam or bubble like soapy water, but be oil based.
Fred There is no such thing as too much cam...just not enough engine. |
