Old 10-11-2007, 03:15 AM   #1
Aussie_C2o
Aussie_C2o's Avatar
8 lug conversion
Hi all, I have a 72 longbed and want to change my stud pattern to 6 lug from 8 lug. I have bought new drop axles for the front that will run C10 rotors. For the rear I am unsure of which way to go. I think I have a Dana 60 FF. I think it will be best for me to identify this first. I was thinking of either getting 2 axles made or change the hubs to 6 lug hubs. Has anyone done this before. Any help please.
Glenn
www.compheads.com.au
Aussie_C2o is offline   Reply With Quote
Old 10-11-2007, 08:56 AM   #2
67_C-30
I have a radical idea!
67_C-30's Avatar
Re: 8 lug conversion
Glenn
Unless the rearend has been cahnged in your truck, its probably an Eaton rearend. In a FF rear the lugs are in the brake drums, not in the axles. It's likely that the hub diamter will be too big to redrill the drums. Changing over to a 6 lug would be the best choice, and would allow a better selection of gear ratios.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 10-11-2007, 04:43 PM   #3
earl87gta
earl87gta's Avatar
some of the 72 had d60 in the back . But you wold be better off getting a 12b 6 lug rear or a 14blt 6 lug but there hard to find here let alone in Australia so the 12blt is your best bet.. I was in your kneck of the wood one time spent 3 month in Amberly i think that what the tome was called on an air base there.or it was when I was at a navy base but im not sure. on the weekend I would take a train to Brisbane or Sidney even went to serfers pairedice once.
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
Old 10-11-2007, 05:31 PM   #4
Aussie_C2o
Aussie_C2o's Avatar
I will take some pics of this diff as it is out of the truck atm and I have a 9" in it. I am not sure where Amberly is, but surfers paradise is very nice. thanks for the replys
FATGM 1972 C20- 500HP 402BBC, Dropped on 20" Billets
Old 10-11-2007, 06:09 PM   #5
earl87gta
earl87gta's Avatar
First pic is a eaton second a 14blt and third is a d60 if your lucky ita a d60 there is a kit to convert it to 6 lug http://www.geartechhd.com/gallery/di...?album=5&pos=6
Earl
Old 10-12-2007, 01:58 AM   #6
Aussie_C2o
Aussie_C2o's Avatar
Mine is definetly the D60. I will check out that site. thanks guys
Old 10-12-2007, 07:45 AM   #7
earl87gta
earl87gta's Avatar
Glad I could help. If you get that convertion kit take lots of pics Ive never seen one used before. It looks like its a high quality kit.
Earl
Old 10-12-2007, 09:48 AM   #8
Aussie_C2o
Aussie_C2o's Avatar
Do you know how much the kit costs? I have emailed them and I'm waiting on cost.
Old 10-12-2007, 04:52 PM   #9
earl87gta
earl87gta's Avatar
No I dont there was a write up on it in one of the 4x4 mags one time but I canrt remeber were. Ill see if I can find it.
Earl
Old 10-12-2007, 05:45 PM   #10
earl87gta
earl87gta's Avatar
I called them and left a mesage if they call me back Ill let you know.
Earl
Old 10-12-2007, 09:20 PM   #11
Aussie_C2o
Aussie_C2o's Avatar
thanks
Old 10-15-2007, 12:52 PM   #12
earl87gta
earl87gta's Avatar
dont know if you got a hold of them but they called me back today. it is $1450 for the kit but it comes with a disk break convertion you have to use disks with it. He said he would ship it to to you no problem.
Earl
Old 10-15-2007, 03:55 PM   #13
Aussie_C2o
Aussie_C2o's Avatar
Thats not too bad considering what you get. Thanks for your help.
Old 10-15-2007, 04:15 PM   #14
earl87gta
earl87gta's Avatar
Glad I could help.
That’s what I was thinking all new hubs and every thing for disk breaks. Let me know if you decide to buy the kit and need me to call him for you or any thing.
Earl
Old 10-15-2007, 04:45 PM   #15
Aussie_C2o
Aussie_C2o's Avatar
Thanks earl, i just got a truck 9 inch and not sure if ill use it. its already 5x5 and 31 spline axles. I'll be saving the 1450, and id prob spend that on a good locker center. what do you think? I also want to bag this thing so the extra cash helps too.
Old 10-15-2007, 07:12 PM   #16
earl87gta
earl87gta's Avatar
I would think for 1450 you could build that 9 up. you could upgrade the axles and put a locker in it and have cash left over.
Earl
