Old 10-11-2007, 12:14 PM   #1
scotts72heavyhalf
scotts72heavyhalf's Avatar
Crankcase vent to aircleaner?
My 72 heavy half ton is on the way back to stock, I have found the stove pipe and heat sheild for the driver manifold and installed it as well as the stock aircleaner, my question is where can I find the crankcase breather hose that connects to the front of the aircleaner to the little plastic filter, in some pictures it looks to come from the passenger valve cover?
scotts72heavyhalf is offline   Reply With Quote
Old 10-11-2007, 12:25 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Crankcase vent to aircleaner?
heavy half? That would make it a 77 or so?
Old 10-11-2007, 12:59 PM   #3
scotts72heavyhalf
Nope, mabye I`m calling it the wrong thing, C10 custom with the leaf spring rearend, trans cooler, 12 bolt rearend, 350\350. What would be correct then?
Old 10-11-2007, 01:24 PM   #4
70GMCer
70GMCer's Avatar
Just a 1/2 ton truck. I think the heavy halfs came out in 73. Again, I think.....Sorry I can't help on the hose....
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 10-11-2007, 01:45 PM   #5
bad_turbo
turbo enthusiast
bad_turbo's Avatar
pics would probably help answer the question faster.
"But daddy, I didn't hit them all with a stick"...what my 6 year old tells me when I pick him up from school early for fighting "
bad_turbo is offline   Reply With Quote
Old 10-11-2007, 01:53 PM   #6
fun in dirt
fun in dirt's Avatar
Any parts store ought to have it. However it may not be listed on their computer; if you go to an old style parts store that still uses catalogs you'll have better luck.
If it was me, I'd just ask if I could look at their hoses & match something up. Alot of the newer year cars have pre-bent heater hoses that you can cut & will do the job.
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432
'85 K30 "Big Nassy"
'01 2500 Suburban ...party wagon & tow truck
'06 Silverado SS...DD
'06 C1500 WT...DD
'07 Classic C1500 WT...DD
Built & sold cause can't keep 'em all:
'72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190
'55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938
'69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541
'86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619
fun in dirt is offline   Reply With Quote
Old 10-11-2007, 09:27 PM   #7
wibilly
wibilly's Avatar
it goes to the spacer under the air cleaner for filtered air intake in to the passenger side valve cover, junk yard or parts board
common sense isn't so common anymore
wibilly is offline   Reply With Quote
